Hi All
Having abit of a cleanout and found my Noltec arms
Before removed I didnt notice any play and still seem solid when levered, but a couple of bushes are chopped around edges
These bushes shagged and need replacing or okay to use as is and good to go?
Photo of worse one attached
Cheers
I would not use them.
Generally, Notlec bushes were great when new, but they disintegrate over time. Even if those were OK now, once you start putting them under pressure at that age they will just crumble.
Worse, there is a reason people stopped using that arm design. It is too easy for the adjusting bolts to come loose leaving you with some excitement when they slip.
Fair enough, although I thought polyurethane bushes dont have a lifespan on age as such and are usually good for the life of a car if not flogged out. Suppose it depends on type and use.
Think i must of got too cranky on the bolts and chewed them,didn't notice when I removed them but it's been awhile
Wouldn't want them slipping mid corner though. One time taking a negative to a positive wouldn't be fun...
Cheers for the reply
No. It's a design "feature" of rigid FUCAs on R32s. The stock arms are rigid and have squidgy bushes to provide some compliance to take up the simply horrible amount of twist that the stupid suspension geometry forces into them on articulation. Polyurethane bushes get squeezed something horrible. Noltec's urethane compound also didn't age well, as per Duncan's report.
Basically, these arms suck for a few different reasons. It's hard to find a workable solution for R32s.
  • 3 years later...
On 9/18/2021 at 11:54 PM, 32R said:
Hi All
Cheers
I'll buy them if you still got them
