This response may be controversial, but I'll get the ball rolling with it as at least it is an answer/some conversation :)
This is basically a pretty solid copy of a Garrett Gen2 GTX3582R, and basically the same copy is sold under different branding as a Pulsar GTX3582R Gen2 - funnily enough.
As such I'd consider using G2 GTX3582R information as a general guide of what you can expect flow wise from these (they're solid!) but also spool wise.  Realistically it's a pretty "big" turbo, definitely laggier than the previous 3582s you could get.  Depends really on what you are looking for power wise, how much lag you're willing to live with (realistically all in after 4500rpm on a RB26) and that general kind of thing.
That is FAR better response than the -5s i run now and on highboost am maxing those suckers at 430kw at rear wheels and 11.1@127mph on the 1/4 with 225 goodyear eagle d5's on haha.
I am liking the sound of this turbo to be honest.
To be fair, "after 4500rpm" is pretty open ended haha.  The power versus response on the "6662" I would expect to be a fair bit better, but would expect it to be a reasonable amount lazier in the lower rpm than -5s - yours seems laggy, even for those.  Are you actually looking for more response, more power, or a good combo?
I have in my head you're Kiwi/NZ based?   I'd consider talking to @infomotive as he is a NZ based Pulsar turbo dealer, and already has a fair bit of direct experience with running these turbos on RBs so can probably give you some realistic expectations on the G2 GTX3582R spec thing in terms of power/response or other suggestions.
  • Like 1
On 21/09/2021 at 8:13 PM, Stixbnr32 said:
You are correct Auckland based.
Just want a good return on going single - after a "good combo".
Cool i will contact Infomotive.
Let us know what you decide on, and how it goes :)
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
