Hey all
Today Im selling my power fc w/handcontroller to suit a R34 Gtt rb25det neo and fc-hako like device, it's called Wite device which plugs into the hand controller port and allows you to tune via usb/Bluetooth or WiFi I've posted the link to the wite device to see all its features like
RealDash (iOS, Android, Win10)
Power FC tuning software FC-Edit (via PC cable or BT), CoPilot (via PC cable or BT)
 http://witedevices.com/
Which cost me a extra $350 comes with all cables and bt module
All working perfectly upgrading to haltech elite 2500
Comes with everything
1.Power fc unit
2.hand controller
3.Wite device with all cables and bt module
4.power fc boost control kit
Power fc model number (PFC Er34 010-0212
Happy to send aus wide postal insurance a must
$1500 located eastern suburbs Melbourne 323817020_Screenshot_20211001-010902_SamsungInternet.thumb.jpg.dc215ca6edc05307211762c1c2939fa3.jpg
Edited by jet2nv
Added location
Will also include a z32 afm and plug. Price is Negotiable
So R34 gtt power fc with hand controller plus a plug in wifi/Bluetooth tuning capabilities better then fc-hako and data-logit
Can wirelessly connect to your phone/tablet Android he's unit and sync with Realdash app for live stat's/data and can even be tuned remotely via your tuner.
Plus it comes with a genuine Z32 afm and plug
  • 1 year later...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
