After much whining over the years over the quality/readability of the wiring diagrams in the age old pdf scan of the R32 GTR workshop manual, I pulled my copy out and ran it over the scanner.
Now, it's not perfect. My paper sheets are assembled from photocopies of the originals that I had to tape together. So there are slight discontinuities here and there. On top of that, I had to scan my long taped together sheets as A4 segments and reassemble them on screen, which involved rotating some parts by little angles like 0.15°. But they are pretty good. On top of that, I have left jpgs of the raw individual scanned parts for each numbered assembled scan so you can see the points where they join without any little artefacts caused by my manual stitching.R32 GTR Wiring Diags.zip
The quality of the scan is much better than the old pdf, but there is only so much detail that can be pulled out of the original photocopy. Most of the wiring numbers and colours that were hard to read before are a better, but some remain fairly hard to see. I tried 600dpi scans and it didn't help at all. This is about as good as it gets unless someone scans an original.
*update Jan 2024*
Thanks to GTSBoy for the previous photocopy scans and suggestion on how to obtain higher quality scans. I actually have the original printed manual and have finally scanned the wiring pages from it.
R32-wiring-hi-res.zip
The quality is better than was available from the photocopies and pretty much everything is readable if you zoom in far enough; it is only some of the physical wiring pin references that are a little hard to read (which is true in the printed original too).
Edited by Duncan
Update with higher quality scans
  • Like 2
  • Thanks 7
Thanks on behalf over everyone who will use these but never consider that someone put in the time to do them :) These copies are definitely much better than the ones in the pdf
I do actually have the original originals that I could scan too, but as you described I don't really know the best way to deal with the very wide fold out pages.  If anyone has suggestions on a way to get a better outcome let me know and I can give it a go.
  • Like 1
Wow that makes a huge difference. The wire labelling is so much clearer, makes everything easier to follow.
I'll be printing these out to replace my dogeared prints of the old pdf/scan.
Thanks for sharing.
Edited by alexj
The time is worth it to simplify future efforts to help peeps on here.
You just have to scan them on any A4 (or better, A3) flatbed in pieces with enough overlap to allow reassembly and keeping them dead straight. Gray scale 300dpi will do. Then assemble in a graphics program like the Gimp. I tried using stitching software but it can't cope - it's designed for photo panoramas.
If you want to put the time into scanning the original, you could upload them to OneDrive/Google/whatever and I'll stitch them.
  • 3 weeks later...
  • Duncan pinned this topic
  • 11 months later...
OK, so if you haven't seen in the first post, per GTSBoy's suggestion I have done high res scans form the original printed manual (instead of the photocopy which is not the same quality)
Zip file of the all diagrams (excludes Oz specific, they are in the first post if you need them)
C-1 Logical Wiring diagram (better for understanding)
W-1 Physical Wiring diagram (if you are trying to physically trace something)
RB26DETT Physical wiring diagram
W-3 ATTESSA physical wiring
W-4 Door physical wiring
W-5 HICAS physical wiring
W-6 Air con physical wiring
  • Like 4
  • Thanks 1
It was very high tech :) Officeworks A3 scanner at 300dpi black and white, then stitch each A3 scan together manually in paint. It has worked pretty OK, you can see the folds in some early scans but I back folded the later ones and they were OK
  • Thanks 1
Absolute Legend 🍻
After fighting with the scanned ones for the last 10 years this is a God send
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
