Garage clean out - parts available for pickup from Canberra ACT or postage at buyers expense. Will get quotes on request.
Apexi Power FC to suit R32 or R33 GTR. Comes with hand controller $450
CAS to suit RB26. This has done approx 2000 only so has hardly done any work. $250
RB26 Low impedance ballast resistor pack $50
Brand new low pressure high volume in tank fuel pump. Was going to use this as an in tank lift pump to fill surge tank in boot but went a different direction. Brand new in box and never used and paid $130 - only opened for pics $80
Z32 airflow meters x 2 $100 the pair
Low impedance 740cc injectors. Working and as removed from operating vehicle but not cleaned $250
Haltech Elite 2500 ECU R32, 33, 34 adapter harness to stock ecu plug. Auxiliary plug has been messed with so will probably need replacing but otherwise good condition. Sells for $715 on Haltech website so selling for $350
https://www.sau.com.au/forums/topic/482881-r32-gtr-parts/
  • 1 month later...
  • 4 weeks later...
Now sold:
power FC
Injectors
z32 AFMs
Now for sale:
HKS GT SS twin turbos
comes with matching stainless dump pipes with seperate wastegate pipes. None to very little bearing movement and both compressor and exhaust turbines in great condition with no visible damage. Oil dump pipes were replaced not very long ago and have not had much use either. Comes with fabricated aluminium intake pipes and air filters to suit R32. More pics available on request.
$1600
Edited by Milhouse
https://www.sau.com.au/forums/topic/482881-r32-gtr-parts/#findComment-7958393
  • 1 month later...
  • 5 months later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
