Garage clean out - parts available for pickup from Canberra ACT or postage at buyers expense. Will get quotes on request.
Apexi Power FC to suit R32 or R33 GTR. Comes with hand controller $450
CAS to suit RB26. This has done approx 2000 only so has hardly done any work. $250
RB26 Low impedance ballast resistor pack $50
Brand new low pressure high volume in tank fuel pump. Was going to use this as an in tank lift pump to fill surge tank in boot but went a different direction. Brand new in box and never used and paid $130 - only opened for pics $80
Z32 airflow meters x 2 $100 the pair
Low impedance 740cc injectors. Working and as removed from operating vehicle but not cleaned $250
Haltech Elite 2500 ECU R32, 33, 34 adapter harness to stock ecu plug. Auxiliary plug has been messed with so will probably need replacing but otherwise good condition. Sells for $715 on Haltech website so selling for $350
https://www.sau.com.au/forums/topic/482881-r32-gtr-parts/
  • 1 month later...
  • 4 weeks later...
Now sold:
power FC
Injectors
z32 AFMs
Now for sale:
HKS GT SS twin turbos
comes with matching stainless dump pipes with seperate wastegate pipes. None to very little bearing movement and both compressor and exhaust turbines in great condition with no visible damage. Oil dump pipes were replaced not very long ago and have not had much use either. Comes with fabricated aluminium intake pipes and air filters to suit R32. More pics available on request.
$1600
Edited by Milhouse
https://www.sau.com.au/forums/topic/482881-r32-gtr-parts/#findComment-7958393
  • 1 month later...
  • 5 months later...
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
