Hey there everyone,
I've got my 4WD light on at the moment and have the code "5,6" on the attessa module with the led light. From what I can see that means "E-TS oil level switch and/or circuit".
Could this be a faulty fuse, switch or possibly the system needs to be bled (considering the gearbox, engine and transfer case were just out)? What is the most common cause for this problem? Thanks everyone!
On 4/10/21 at 8:10 PM, Aiden7 said:
Hey there everyone,
First thing i would check is the oil level in the boot, then I’d bleed the 4wd system
On 04/10/2021 at 6:40 PM, Aiden7 said:
Hey there everyone,
OK what's it doing on the 4wd ecu ? When you say 5, 6 what do you mean ? On 33 GTR code 56 as you mentioned is low fluid level, but is indicated by 5 fast flashes then 6 slow flashes. If you have 5 slow then 6 slow flashes that is codes 5 and 6 not 56, which is your front right and left abs speed sensors in fault.
If so this could be an indication that they are not connected in the engine bay.
