HKS VCam Step Pro + Carillo Pistons - 9.5:1 - Has anyone does this before?
Hi Everyone
I'm in the process of building my RB28 engine and I have basically got everything here ready to be assembled. Currently have an extensively modified head (Shimless buckets, 1mm oversize valves, ported, clearanced, springs, Kelford 272, 10.25mm lift cams.
Pistons are CP Custom 9.5:1
Crank is a 2.8 Stroker.
I want to fit a HKS VCam Step pro with the 264 / 10mm lift.
I'm aware that the HKS VCam kit needs the HKS pistons that have a larger valve relief to obtain 50 degrees advance.
I've spoken to someone that has done the CP + VCam Step Pro and they said they got 32 degrees of advance before there would be clearance issues.
So, my question is pretty simple - Has anyone does this combination before and can confirm this? I would be pretty happy with 30 degrees advance because that is still a decent gain.
We would be installing a stopper once we know how far it can be advanced.
Thanks in advance for any information.
Can’t just put larger valve reliefs in the slugs? So many factors come into this and really can’t be answered without the donk being assembled and measured.
- head been decked?
- block been decked?
- rod to stroke ratio…
- gasket thickness?
- depth of relief
- valve size
Measure it up and work backwards from there. There isn’t ANY other way to know.
I would be disturbing the structure of the piston by doing this.
The HKS VCam was a late choice. I know, bad idea but It's apparently been done. Just can't run the full amount of advance which I'm okay with.
You could always ask CP how much valve relief you can mill into the pistons before it's a problem. I know some tuners out there mill valve relief out of the stock pistons to get the full 50 degrees of cam advance on an otherwise stock engine.
I've been thinking about this. If a Step1 kit can go onto a stock engine and move to 30 degrees advanced, I think a Step Pro should be able to do relatively the same because the CP pistons will almost be the same valve recess area and piston to quench area.
I should be able to get about 30 degrees out of the 50 degree kit which will be still a significant upgrade.
The engine builder is going to measure everything up for me and see how much advance I will have.
Except step 1 is 8.6 mm of lift and pro is 10.0mm or whatever it is, Plus the different ramp rates and durations of the cams.
So many variables. Can’t compare a factory engine to your built one as so much can change.
Step 1 moves 90-120
Step 2 moves 75-125
Pro moves 80 - 130
Another variable.
Yeah we thought about that too. Sorry I should have mentioned that in my post. Once we have built the bottom end and have dummied up the head we will have a better indication on how much piston to valve clearance we have.
I'll make sure I post the results so there are answers. It's always good to know this stuff.
  • Like 2
  • 4 weeks later...
okay, so I had issues with sourcing a 0.8mm Apexi head gasket and purchased the Nismo 0.9mm gasket.
Careful measurement with the engine dummy assembled showed that with these particular pistons, and Kelford 272, 10.15mm lift cams, at 35 degrees advance I have 2.15mm clearance from the piston at the closest point of the valve lift.
The pro cams have slightly less lift at 10mm.
A pro kit will work fine locked out at 35 degrees or less. 35 degrees is still a massive gain to be had.
  • Like 1
I did a Step II with 9:1 comp pistons and there was a good amount of clearance, the go was to mock it up and advance the cam 50 degrees one way see if engine is still non interferance and then 50 degrees the other way and repeat on the stand I was not going to risk guesswork at all
Yes now I have Vcam Pro going for 10:1 comp pistons and the go was to get custom pistons made with a dome shape that doesn't interfere where the valves normally travel to
Edited by RB335
    • Curious if you've discussed this with them, maybe they can remove it for you since you requested it not to be coated.
    • Thanks Rezz...   👍
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
