HKS VCam Step Pro + Carillo Pistons - 9.5:1 - Has anyone does this before?
Hi Everyone
I'm in the process of building my RB28 engine and I have basically got everything here ready to be assembled. Currently have an extensively modified head (Shimless buckets, 1mm oversize valves, ported, clearanced, springs, Kelford 272, 10.25mm lift cams.
Pistons are CP Custom 9.5:1
Crank is a 2.8 Stroker.
I want to fit a HKS VCam Step pro with the 264 / 10mm lift.
I'm aware that the HKS VCam kit needs the HKS pistons that have a larger valve relief to obtain 50 degrees advance.
I've spoken to someone that has done the CP + VCam Step Pro and they said they got 32 degrees of advance before there would be clearance issues.
So, my question is pretty simple - Has anyone does this combination before and can confirm this? I would be pretty happy with 30 degrees advance because that is still a decent gain.
We would be installing a stopper once we know how far it can be advanced.
Thanks in advance for any information.
Can’t just put larger valve reliefs in the slugs? So many factors come into this and really can’t be answered without the donk being assembled and measured.
- head been decked?
- block been decked?
- rod to stroke ratio…
- gasket thickness?
- depth of relief
- valve size
Measure it up and work backwards from there. There isn’t ANY other way to know.
I would be disturbing the structure of the piston by doing this.
The HKS VCam was a late choice. I know, bad idea but It's apparently been done. Just can't run the full amount of advance which I'm okay with.
You could always ask CP how much valve relief you can mill into the pistons before it's a problem. I know some tuners out there mill valve relief out of the stock pistons to get the full 50 degrees of cam advance on an otherwise stock engine.
I've been thinking about this. If a Step1 kit can go onto a stock engine and move to 30 degrees advanced, I think a Step Pro should be able to do relatively the same because the CP pistons will almost be the same valve recess area and piston to quench area.
I should be able to get about 30 degrees out of the 50 degree kit which will be still a significant upgrade.
The engine builder is going to measure everything up for me and see how much advance I will have.
Except step 1 is 8.6 mm of lift and pro is 10.0mm or whatever it is, Plus the different ramp rates and durations of the cams.
So many variables. Can’t compare a factory engine to your built one as so much can change.
Step 1 moves 90-120
Step 2 moves 75-125
Pro moves 80 - 130
Another variable.
Yeah we thought about that too. Sorry I should have mentioned that in my post. Once we have built the bottom end and have dummied up the head we will have a better indication on how much piston to valve clearance we have.
I'll make sure I post the results so there are answers. It's always good to know this stuff.
  • Like 2
  • 4 weeks later...
okay, so I had issues with sourcing a 0.8mm Apexi head gasket and purchased the Nismo 0.9mm gasket.
Careful measurement with the engine dummy assembled showed that with these particular pistons, and Kelford 272, 10.15mm lift cams, at 35 degrees advance I have 2.15mm clearance from the piston at the closest point of the valve lift.
The pro cams have slightly less lift at 10mm.
A pro kit will work fine locked out at 35 degrees or less. 35 degrees is still a massive gain to be had.
  • Like 1
I did a Step II with 9:1 comp pistons and there was a good amount of clearance, the go was to mock it up and advance the cam 50 degrees one way see if engine is still non interferance and then 50 degrees the other way and repeat on the stand I was not going to risk guesswork at all
Yes now I have Vcam Pro going for 10:1 comp pistons and the go was to get custom pistons made with a dome shape that doesn't interfere where the valves normally travel to
Edited by RB335
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
