Hey all!
First time posting, so I hope I've done it correctly
I got a nice rattle happening but never noticed it before.
Engine has low kms but haven't done the timing belt yet :p.  It has sat around for a couple years but always started and moved around every week and kept garaged,  so I'm assuming its something timing belt related.  I took a quick video to help.. I swear it has done this since 39kms.
https://youtu.be/kLM67uO0H8g
https://youtube.com/shorts/YIZLiaYrHpQ?feature=share
Hope im allowed to post these as I keep getting server error when trying to attach a file... even upload a profile pic :/
Thanks
https://www.sau.com.au/forums/topic/482911-r33-rb25-front-engine-noise/
On 12/10/2021 at 2:14 PM, ryanr2500 said:
Hey all!
Thanks
Motor sounds like it has a bottom end knock as mysteriously eluded to - especially first video.
@Duncan has been very polite, and I commend you on your restraint there mate 😄, I won't be -
It's fcked....
Noises like that don't get any better or go away by themselves.
If in doubt - engine out.
Thanks for the replies guys!
I just checked then, and there is definitely no noise underneath..  I know what knocking sounds like but this sound more like a bearing or something in the front thats revolutionary, its under the timing cover im pretty sure..
this thing has only done 85k kms so id hate to think it was knocking already, especially driving around on stock boost and very well maintained(well.... apart form this).
ive only hit the limiter in this 3 times in 11 years, i did get shit for buying a skyline and not hammering it... not even a single burnout lol.
oh na dont hold back on me, go hard as.  :)
I'm not saying I know what it is, but to me it doesn't sound like it's knocking. When my VQ35 started knocking, the noise was more of a defined knock, where this sounds like a groan, from vibration I presume.
How's your oil pressure?
Yeah oil pressure will be a good guide for a bearing issue, but the noise getting worse when reving is a pretty clear indicator of a big end bearing issue.
Still, if you think it is front of engine, the top timing cover can be removed and you can still run the engine, so that is worth a try. There are bearings under there for the timing belt idler and tensioner so it is not impossible
Either way, the less you run the engine, the less further damage occurs.
  • Like 1
Oil pressure was just under 8kg/cm2(full) on cold start, comes down to just under 4 on idle.
I wont get time till tomorrow to take the cover off and have a look.  I can hear it on idle but very very softly.
Ill let you know how it goes!
Just started this topic in case someone else has this issue also.
Thanks !
Does it go away when the motor is warm? If it sounds like its under the timing cover, it could be a lazy lifter.
Edit: Just listened and doesn't sound like one, but always hard to tell unless your right there.
Try removing your front belts and trying for a few seconds, eliminate alternator, water pump power steering noises etc
Thanks !
I take it that's from the extremely inaccurate factory gauge ?
On 13/10/2021 at 9:37 PM, GTSBoy said:
Are there any other pressure gauges in the world that use the stupid f**king units of kg/cm^2 ?
Anything from Japan, but yes I know right ?  I just see that measurement and instantly see it as bar, as its close enough to the same thing
Also wanted to see if there was any acknowledgement of the fact of having no idea what the oil pressure is in this situation reading the factory gauge, as your not having 8bar cold idle or 4bar hot idle in reality are you ?
Sound is there still when warm.
Yeh ill try that after i take the cover off !
Ill take a video on cold start and hot idle for oil pressure soon :)
Im having a hard time removing the plastic cover the protects the vct cable from hitting the fan...  not as easy as the videos say it is :(  I hate old plastic !!  they said flick it forwards..nope.. pull it upwards, nope..  the metal bracket its sitting on is starting to flex outwards :/.  I really dont want to forcibly remove it.  dont think its ever been removed.
It's not metric. It is a bullshit unit.
The unit of force is Newtons, not kg. The kg is a unit of mass. It is not even a unit of weight, because technically there is no such thing as a unit of weight. Weight is force, and the force depends on the acceleration or the local gravitational field. So, here on the surface of Earth, where the local gravity is about 9.807 m/s^2, the force created by a resting 1kg of mass is 9.807 N. If you express that as kg of "weight", what you are saying is kg.f (meaning "kilograms force"), which as I said before, is meaningless. Because on Mars, the force you'd get from 1kg of mass is about 1/3 of what is here. On the Moon, about 1/6, and on Jupiter it's like 2.5x as much or something.
The next bit of bullshit is the use of centimeters. Builders use mm. Engineers and scientists use metres. Only dressmakers use cm. And no-one should use square centimetres for anything.
The only acceptable units of pressure are those that are mutliples of Pascals, or those that are understood to be exactly equivalent to a multiple of Pa. 1 Newton per square metre. Lovely. Anyone caught using N/mm^2 should have their thumbs pulled off. That's an MPa.
So, the use of a bullshit unit of force divided by a bullshit unit of area, to produce a bullshit unit of pressure that is close to but not actually numerically the same as a quite reasonably good near SI unit of pressure (the bar, being 100 kPa) is bullshit.
I only use psi and inches and feet and atmospheres and cubic furlongs because those are the standard bullshit units used by a disturbingly large fraction of the population and you simply cannot break the inertia. But there is no reason to go along with a double bullshit unit like kg/cm^2.
  • Like 3
  • Haha 1
On 14/10/2021 at 9:45 AM, niZmO_Man said:
pooping on metric, coming from you, shame :P
As pointed out metric is really pascal in pressure.
Kg/cm2 about as useful as measuring power in PS, and possibly HP for that matter instead of watts.
Good rant, will drop by again
  • Like 1
Worth a shot, but not saying this will be it
I had issues with my CAS a long time ago after i disturbed it when I did my timing belt. Spent a long time taking top timing cover off and running, and putting it back on and running
Noise went away with it off and CAS mounted, came back when cover was back on with CAS Mounted
From memory the spacers were not installed in the gasket or something fun along those lines. Eventually ended up replacing the CAS to as it had a horrible bearing noise
It was already suggested above but it would be worthwhile taking the top timing cover off and see if noise goes away
  • Like 1
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
