Hello,
So I just recently bought a rb26dett for my 1992 r32 gtst. I've been told I need I'll need a new cross member and drive shaft to make it fit, I know I needed a new shaft but didn't know about the cross member. What cross member will fit for a rb25 trans to a 26 motor? And what drive shaft would be best? I am also having trouble finding an adapter plate. Any info would be greatly appreciated
Edited by Brianna-32
https://www.sau.com.au/forums/topic/482926-r32-gtst-swapped-rb26dett/
You don't need a new crossmember. The GTR crossmember cannot be put into the RWD chasssis anyway.
You just need engine mounts, and I'm pretty sure your RB20 ones will fit. If they don't google up what other people have done. It's not hard.
What gearbox are you going to use? Don't say the GTR gearbox, because it won't fit. It just won't fit. Don't even think about it. And don't say you're going to use the RB20 gearbox, because it won't survive. The RB26 makes more torque than the little box can handle.
You will need an RB25DET gearbox. And then you will need the front half of a tailshaft to suit, and then you will need to take your R32 tailshaft and the front half of the (likely R33) shaft and some careful measurements to a drive/shaft manufacturer (like Hardie Spicer) and get them cut and shut together.
There is no other way to do the tailshaft properly. Nothing off the shelf will work.
/\ You'll need to cut the diff off the 26 sump & usually grind the fins on the bottom a bit to clear the gtst xmember.
You can cut the transfer off the 26 box & use it but no point if you have a 25 box, not sure what adaptor plate you're looking for, bell housings are same
  • 1 month later...
Don't hack up the 26-parts, you can sell the sump, diff and trans for a pretty penny.
Neo RB25 5spds are still available new and you can always grab a used RB25 Trans. They also make adapter plates to run a modified CD09 out of a Z33/Z34 and you can get bellhousings for the T-56 / Magnum.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
