Hey All,
Just clearing the Dose Pipe shed, since I need the space 😁
R33 PWR Radiator (has slight damage)
Condenser rubbed on it and leaked. Has been JB welded, even drove home from Wakefield then the motor seized from oiling issues during the day lolololol.
Suitable for repair OR someone needing a good core to cut down and make smaller radiators. These cores are super efficient!
R33 RB25DET stock balancer, near new!
Off my previous built motor, probably hasn't seen more than 5000km before the motor exploded.
RB2xDE/T Gates Timing Belt, near new!
R33/R34 RB25DET engine fan
No cut fins, has usual cracks.
R33 RB25DE/T accelerator cable & pedal
Decent condition, removed to go DBW
Happy to drop off to you if you're nearby.
Balancer sold
Pedal & throttle cable sold
Take the rest of the other stuff for $50
  • 3 weeks later...
Radiator and fan sold
Still have the gates timing belt, great for someone that just wants to get their car going or to just test something.
Happy for it to go for free if anyone wants it.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
