I recently recieved this sub/amp setup from my uncle for my birthday. 600W MegaVox Competition Amp and 2 x 10" Marathon subs in a Marathon competition sub box. I have a 200W power supply that I used to test them as they are 20-25 years old. When connected to the 200W (12V @ 18A) power supply the subs could play sound (used an RCA to 3.5mm adapter that came with it) but was dropping out, which I assume is to be expected considering I was running a 600W amp off a 200W power supply. After this I installed them in my mates car ( AU Falcon, his wiring was all setup as he has subs of his own) by taking the wiring from his subs and connecting it to mine. When the car was started the amp powered up, but wasn't able to get any sound either from the head unit or the 3.5mm jack adaptor. Checked the voltage running through the power input and it read 14 Volts (normal as AU Falcons charge at 14V apparently). after fiddling around trying to get it to work i took them out and hooked them up to the power supply and it was back to being choppy but could still get sound.
Any help or insight into why I can't get sound from the subs in the car but can off a 200W power supply would be greatly appreciated
Cheers, Blake
https://www.sau.com.au/forums/topic/482968-subamplifier-problems/
Cheers, Blake
Not sure why you have bridged the outputs like that.  The actual little wire in the middle isn't needed, and probably causes issues. Take it out and see what happens.
its the remote/switch input. bridged to power so that it turns on whenever it recieves power. will give it a try soon, just confused as it works fine with power supply but not in the car.
also i thought it could be going into protection mode, but it doesnt make sense to me as the ground works perfectly on his subs and off the power supply both speakers work.
The amp is probably going into protection mode with the outputs bridged like that. That's not how you bridge channels together.
They do not act like AA batteries.
Also using that kind of wiring for power will cause more issues.
Also with the cost of car audio dropping exponentially, you'll be silly not to run a small footprint marine amp. Here's a fantastic one for the price.
The below amp would destroy what you have there in terms of power delivery, SQ, size, heat manage, etc.
https://frankiesautoelectrics.com.au/clarion-xc2410-400w-micro-size-4-3-2-channel-class-d-marine-amplifier/?gclid=Cj0KCQjw_fiLBhDOARIsAF4khR3wzCm4oVysGSSApkJvO81oVKIuGFZln-lEvBhk6526rHRAXp3pV8caAts8EALw_wcB
Clarion XC2410 400W Micro Size 4/3/2 Channel Class D Marine Amplifier
That's not what I am referring to. There is a wire that shouldn't be there on the speaker outputs.
Righto man, cheers. Itll still run without that bridge on both outputs? or will i have to run another cable somewhere?
Yeah, we were running 50amp wiring in the car this was just the setup we used for the power supply to test it as it was a spur of the moment decision. regarding the output bridging do i just remove the cable bridging the negative to positive and leave it? or do i run speaker wire's from both to the respective parts of the speaker?
as you can probably tell im very new to this sort of stuff haha, only time ive hooked up subs had a built in amp and just needed power, ground, remote and input. all other wiring seems alright though?
On 11/1/2021 at 1:41 PM, blakemcdonnell said:
so literally just take it out and it should be fine?
As in.....it won't blow up, which we're all surprised that it hasn't already with the way it is wired now?
Yes.
You should do a little google on what it means to bridge an amp, and how it is achieved, so you at least understand, rather than flying blind.
Then the next question, can you even bridge channels with that amp?
There are no physical markings saying you can bridge these channels.
Honestly, just buy that Clarion amp I posted up above. Cheaper than a car catching on fire.
Yes.
hahaha fair enough, this is just how i recieved them from my uncle. unless hes changed the wiring, this is how he ran it in the 90s. very confused as i cant find anything about the amp on google at all. i will probably end up buying that amp to be honest. what should i be looking for besides on google to see if they can be bridged?
Amps probably stuffed, might be a blown capacitor or three. So weird with that wiring setup, I'm surprised it worked haha.
Just get a Class D or mono amp (rated higher than the RMS of the subs, check impedance), save yourself the hassle.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
