Hi All,
Found an old post you commented on from 2006
"On Skylines the spindles (vertical suspension arms) can and do bend. If so the easiest (best) method of fixing it is to replace the thing. Don't bodge the thing up - fix whats wrong."
Is there a easy way to tell this has bent if not visually (tried to measure same points on the other side but was the same and im not sure I am doing it correctly).
Long story - had my car in for alignment (they ended up running out of time so they just took my measurements).
Anyway my front left KingPin Angle is out (its 10 degrees vs 17 on the right) with 5 castor.
Cannot for the life of me figure out what is up with it, the adjustable camber arms are both set to the exact same length and the lower control arm seems fine (measures 315mm hole to hole same as the drivers side)
Alignment looks like
Front
Toe L-2 R-2
Camber L-1.35 R-1.33
Caster L5.44 R 5.22
Kingpin L 10 degrees R 17 degrees
Could be the upright is bent, but that's not really a common problem.
Could be bent/moved subframe. Could be the whole car is bent, having had a front ender and not put back straight.
I would suggest taking it to the sort of chassis shop that crash repairers use when they can't get  car straight again. If you were in SA I would suggest someone to look at it. Can't do that for anyone else.
You'll never work this shit out for yourself. You don't have the kit for making these sorts of measurements.
Thanks GTSboy, appreciate the input I think that will be the best route to take.
It hasnt had a hit in my 13 years of ownership and the kingpin angle was fine (11/12) when I had it aligned 3 years back now
Ill track down a shop in Vic to get it measured up for the subframe  and all
Expand
Try R Kent and sons in Clayton north. They'll be able to work it out for you.
    • Ahhh, that, yeah, but it all worked out well in the end As for the ITB noises, I don't really wind it out with her in the car, and the dort only really starts dorting hard when your WOT or up it hard
    • It wasn't about the dollars. I mean how she didn't like the loud exhaust and you had to change it again 馃槢
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
