Hi all
Am about to do a digital dash swap in my 32 GTR, and am currently investigating the speedo signal issue. I'll be converting the car to run an electronic speed sensor using an R33 GTR unit, and wiring that into the ECU to give it a speed signal.
My question is, will I also have to do something with the atessa system, since the OEM speedometer will no longer be fitted? Am struggling to get clarity anywhere as to whether the R32 Atessa system uses the OEM speedometer output for any of the stuff it does.
Any insight will be appreciated!
R32s have cable speedo drive to the speedo head. The speedo head creates the one and only speed signal (VSS) in the car. That speed signal is a square wave (PWM) signal that varies in duty (on time) with speed. You can see the waveforms in the workshop manual.
R33s have an electronic speedo sender. That feeds an AC sawtooth wave signal to the speedo head. The speedo head then creates essentially the same squarewave signal that the R32 speedo head does. The details might be different, but it is otherwise the same type of signal. This again, is the only speed signal in the car.
So, presuming you do use an R33 electronic sender, you will need to convert that from AC sawtooth to a squarewave with the same characteristics as the original one from the original speedo head. If you don't, the ATESSA will either not see it or it will misinterpret it, with whatever shitty results come from those options.
You do not need to do anything with the ATESSA system. You just need to feed it what it wants. And that's just a matter of creating the right signal. You might be able to do that in the dash, or you might be able to do it in the ECU. Or, if desperate, you could do it in an Arduino, which is relatively trivial these days.
    • how do you know voltage is fine?  quick easy test is connect DMM up and put it on max/min mode, remove fuel pump fuse, crank car for 3-5s, go check min voltage You'd be surprised how many "healthy" batteries are showing under 10v during this test in cold weather.
    • Not properly. You need to be able to dissipate 100 amps or so to doing it meaningfully. You can do it indirectly by watching to see how far the voltage falls during cranking. Unplug the coils or something else to prevent it from starting so you can get a good couple or three chugs. It also helps if you have the multimeter set up reading before you start, and that it has max/min functions. So you can catch the real minimum without having to watch the screen, which often doesn't update fast enough to show the real max/min in dynamic situations. Or use a digital oscilloscope, which can be obtained for <<$100 from Aliexpress (although I'd argue for paying up to ~$200 for a nicer one). A >4 yr old battery will very likely be well down the path to the knackery. Many only last 5-6 years these days. The cold weather lately will definitely make it worse.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
