Hi all
Am about to do a digital dash swap in my 32 GTR, and am currently investigating the speedo signal issue. I'll be converting the car to run an electronic speed sensor using an R33 GTR unit, and wiring that into the ECU to give it a speed signal.
My question is, will I also have to do something with the atessa system, since the OEM speedometer will no longer be fitted? Am struggling to get clarity anywhere as to whether the R32 Atessa system uses the OEM speedometer output for any of the stuff it does.
Any insight will be appreciated!
R32s have cable speedo drive to the speedo head. The speedo head creates the one and only speed signal (VSS) in the car. That speed signal is a square wave (PWM) signal that varies in duty (on time) with speed. You can see the waveforms in the workshop manual.
R33s have an electronic speedo sender. That feeds an AC sawtooth wave signal to the speedo head. The speedo head then creates essentially the same squarewave signal that the R32 speedo head does. The details might be different, but it is otherwise the same type of signal. This again, is the only speed signal in the car.
So, presuming you do use an R33 electronic sender, you will need to convert that from AC sawtooth to a squarewave with the same characteristics as the original one from the original speedo head. If you don't, the ATESSA will either not see it or it will misinterpret it, with whatever shitty results come from those options.
You do not need to do anything with the ATESSA system. You just need to feed it what it wants. And that's just a matter of creating the right signal. You might be able to do that in the dash, or you might be able to do it in the ECU. Or, if desperate, you could do it in an Arduino, which is relatively trivial these days.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
