Have two quick spark related questions for everyone. I'm in the middle of building a stroked 2.8 and shooting for around 600kw. I'm expecting to run around 35psi to get there with my gen2 6466.
1st - Will good condition splitfire coilpacks have any issues around that pressure/hp? Should I just purchase r35 coilpacks to be safe or am I wasting my money?
2nd - As for sparkplugs, I'm planning on running 8's with a .6mm gap. Will this suffice?
Thanks
Edited by TurboTapin
https://www.sau.com.au/forums/topic/483017-sparkplugscoilpacks-600kw/
They could be good, or they could struggle. I'd be worried that they're not good enough. It's not as if Splitfires are actually any better than brand new OEM coils. They're just the same technology level, well made.
This would be my approach to anything above 400kW these days. Eliminate the possibility of trouble.
8 is probably wise. I would want to be running fu(k tons more than 0.6mm gap. That's sufficient argument for R35 coils straight away.
R35 coils and the greatest spark plugs in the world, Denso IK01-24 or NGK R7434-8 and forget about it for a couple of years.
they can be had from RHD japan for relatively reasonable money. supercheap will hit you for $99 a plug.
Edited by burn4005
Could you explain the advantage of the Denso/NGK plugs you listed? Spark power, longevity, or something else my brain can't think of?
Yes - The NGK R racing plugs have iridium or platinum ground electrodes with a much higher melting point vs the iridium ix plugs having an iridium centre and nickel ground, so if you value your engine on a big dollar build you will run nothing else. A big detonation event or lean out and there goes your ground electrode through your cylinder.
Also they are available in colder heat ranges like 8 and 9 and have a concealed centre electrode which is helpful for large boost applications.
I personally have blown tips off the ix iridium plugs destroying my engine before and refuse to use anything else in a 400kw + engine now.
  • Like 2
DENSO IK01 24 IRIDIUM Denso racing track race dedicated special spark  plugs|plug f|plug playerplug and play solar power - AliExpress
the ground strap is pure platinum, and very short which keeps it cool to avoid pre-ignition events. electrode is iridium with a pointed tip. gap is fixed to 0.7mm.
very concentrated electric field, ground strap very good at dissipating heat and resisting ablation.
  • Like 2
Shouldn't we be using NGK R7436 (JIS 53mm) instead of R7434 (ISO 50.5mm)?
Yes that's exactly what I use on the 2.8. Having said that the plugs really jam into the R35 coilpacks hard - so much so that when you remove them the stalks usually come away from coilpack and get stuck on the plug which is totally annoying, requiring the entire one piece coil bracket to be removed to retrieve them. This is using the Godzilla motorsports bracket with R35 coils, so a PRP bracket might not have this problem if the spacing to plug is slightly higher.
The iso shorter length appears it would be a better fit I believe than the longer jic length but am yet to confirm this.
  • Like 1
On 18/01/2022 at 1:54 PM, GTSBoy said:
Some dielectric grease perhaps?
Could try it maybe, but it does appear that the R35 coilpack setup has always felt like the standard jic length, which is the correct ones for RBs, is the culprit. Comparing to stock or splitfires it's definitely more noticeably tight with R35 coilpacks with a BCPR type jic plug.
I'm pretty sure that's the reason @burn4005 is using the iso length instead of the jic as that 3mm shorter plug makes them fit the coil a bit nicer.
It's not that bad really, I'm just a bit pedantic and notice these types of things. The important thing is these plugs definitely are the best in the business.
Good point on R35 coils stalks @BK, I have R35 coilpacks on top of bcp7res (JIS) ATM, also not using PRP coil brackets
Don't have sticking issue but there is bit of gap when just resting coils springs on plugs
I think I'll just order set of JIS plugs as it's fitting ok with R35 coils as is
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
