Hi all
I have conflicting info about the stock s15 jap spec manual injectors
I require the correct cc and lag times for my apexi
I have seen cc range from 440 444 448 and 480cc
And as fo lag times .5 .583 .78ms
As well as confusing the nismo 480 with 1.100ms
My new injectors are 850cc with a lag of .780 at 14volt
Are the stock lag timea measured at 14v also
I did speak with john at fc hacko and recomened i spoke with paulr33
Well, they're not 480, and it wouldn't matter if they were supposed to be 440, 444 or 448, as <1% difference is far smaller than the random tolerances anyway.
As to the dead times.....dunno. But the part numbers are well known and I have seen very good tables listing all Nissan injectors against part # and specs, which I', not going to google up now.
Thanks it more what the apexi wants. I have googled for a few hours with not much definitive as well as the apexi manual. So many people saying they are 480cc i dont belive it myself.
I will be going with the 448cc and .583ms
As a stab in the dark starting point
Im sure alot of people have been down this path.
I have recently sent my OEM RB26 injectors out for service as a part of preparation for California emissions. Also as a part of that because I really don't want to waste perfectly good o-rings 6 months down the road I asked them to test the dead time and all that fun stuff. The spec for the stock injectors at 3 bar was something like 480 cc/min, I got 500 cc/min on average. The OEM ECU reports 0.77 ms dead time, their testing reported closer 0.5 ms. I asked them multiple times whether that made any sense, especially whether 4 bar having roughly similar but slightly lower dead time was normal for old injectors. Their answer was yes. I haven't started engine map development yet so I can't say whether their report was truly accurate but something to think about.
480cc is when it's a 3.5bar.
Stock fuel pressure is 3 bar, they're in the 450cc range.
Also if you're tuning on an ancient GameboyFC ECU just adjust the dead time till you hit stoich with the idle fuel cells at 1.00.
Don't over think it.
  • Like 2
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
