What would be the advantage if any of running PRP billet oil pump gears in an N1 oil pump vs my RB25 oil pump?
RB Tech (lewisengines.com.au) also seems to recommend using a standard pump vs an N1. Why is that!?
Edited by TurboTapin
https://www.sau.com.au/forums/topic/483042-prp-oil-pump-gears-rb2526-vs-n1/
Your oil pump has to have some amount of backlash in the gears, otherwise any little bit of a thermal expansion would probably cause the gears to bind and destroy the entire assembly. When you have a rapid transition from acceleration to deceleration like a hard fuel cut I'm pretty sure that the oil pump gears and the collar on the crank are not staying in perfect contact with each other, instead they're changing RPMs at subtly different rates. So the steady state load you'd predict from something like a pull to 7000 RPM is no longer valid, instead you have to consider the maximum relative acceleration and the resulting impulse from impact when that lash is taken up again.
Some sources: http://www.skylife4ever.com/2011/01/real-problem-with-rb26-oil-pump.html
All issues mentioned are mitigated by running billet gears and a long nose crank. My question pertains more to the oil pump housing differences. I already have an RB25 pump housing I wanted to put billet pump gears in. I was wondering if there's any advantage if I purchase an N1 pump instead and put billet gears into that. Even stranger is I found a link (One in OP) that states the RB25 pump housing is actually preferable which I'm wondering why.
Thanks
Thanks
https://www.gtr.co.uk/threads/n1-oil-pump.565753/#post-5759331
The N1 pump has the same flow rate as an RB26 OEM pump, the difference is basically in the gear dimensions and profile.
Yea that's also my understanding. That's why I'm presuming there's no gain in purchasing an N1 oil pump housing. The PRP billet pump gears are N1 style gears so whether they're in an RB26 or N1 housing, the advantages remain the same.
If you're planning to run N1 style gears, you'll need a RB26 or RB25DET NEO oil pump. They won't fit in a R32/R33 RB25DE/T housing.
Also I suggest you get a brand new pump then fit billet gears to them, this will allow a better fit and also reduce any unwanted movement.
I did the whole N1 gears in a RB25DET NEO pump that had probably 300k km+ on it. Let's say it didn't work out well.
The only thing "wrong" with N1 pumps is that there appeared to be a period in the latter part of the first decade of this century where they were failing. This is not original N1 pumps that came in engines. This was N1 pumps that came from Nissan as spares. What is not clear is if there was a real problem or if they were being destroyed by clumsy installation/usage, which was rife at that time.
They sell both 81mm and 77mm diameter gears for regular or n1 pumps. My pump doesn't have many km's but I'll verifiy clearances prior. I think I'm going to try the 81mm gears in my RB25 pump.
Also food for thought, you buy billet gears, then a new housing and it ends up costing very close to a new Nitto oil pump.
I've done the following:
  • Engine No. 1 - Old housing, new Spool v1.0 gears
    • Gears eventually developed pitting and all sorts of crap
    • Suspect due to clearance issues and gears moved about causing cavitation (broscience)
    • Start up oil pressure issues
  • Engine No. 1 - New Housing, New Spool v2.0 gears
    • Oil pressure issue seem to be resolved
    • No start up oil pressure issues
    • Oil pump worked a bit too good, kept filling the head/catch can, etc. on track days
    • Binned motor from oil starvation
  • Engine No. 2 - Nitto Oil Pump
    • Oil pressure amazing
    • Also have a 5L catch can draining back to sump
    • Nitto Head drain/crank case vent installed
    • Hope to never talk about oil issues again
On this, with my new setup not sure if I should run a new catch can, currently have a Hi Octane catch can, believe it’s 2.5 - 3 litre capacity, its plumbed back to the sump. This was fine with my old RB30 setup, that motor had very little blow by, not sure how the new 2.7 will be? Shop wants me to fit a bigger catch can.
New motor has the new Nitto billet sine drive oil pump.
  • Like 1
Only way to never have oil issues ever again is dry sump
  • Like 2
Do dry sumps even make sense for a street car? Not so much a conceptual issue but the practical realities of finding space for the oil tank, oil pumps, etc.
Seems like these days (with massive boost), most workshops are fitting massive catch cans and returning them to the sump.
I've fit my shit box with a ball valve to switch from street duties (no return) to break stock gearbox mode (return to sump).
Or fit a 2JZ lol.
On 12/4/2021 at 9:48 PM, r32-25t said:
Make enough sense that Porsche come with them factory along with plenty of other cars
A lot of wasted space in skylines may as well use it for the dry sump
Right, but those solutions are usually packaged and designed to work nicely. For a street car that ultimately isn't about outright performance doing all the usual wet sump tricks is probably good enough. Maybe the Hi Octane kit is the way to go there but it's hard for me to say whether it's really "no compromises" for a street car when there's no real photos for how it's installed. The mention of having to swap sway bars, power steering pumps, etc... though definitely gives me pause.
Factory style oil pumps can cause cavitation at high rpm, even as good as the hi octane big sump is even they went to a dry sump in their own time attack car because the only way to guarantee zero oil issues is with a dry sump as my original post stated
For a street car that drives your grandma to bingo it’s “good enough”, but the original person I quoted has every intention of taking their car and cutting laps at the track.
  • Like 2
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
