10 hours ago, TurboTapin said:
There's also another Australian company that makes R32 billet final drives. I can't remember the name though.
Neat Gearboxes
https://www.neatgearboxes.com.au/
1 hour ago, GTSBoy said:
Neat Gearboxes
1 hour ago, robbo_rb180 said:
Yes, that's the one! Thanks. I remember going Speedtek over Neat due to the price but clearly it didn't pay off.
Fun fact, PRP started distributing Speedtek parts back in August. Now there's no mention of them anywhere on their site. I don't want to speculate but all I can say is it didn't take long for that partnership to go awry.
  • Like 1
  • Haha 1
Wow you're right!
Google still shows it, but when you click on it, it takes you to empty pages.
Amazing.
Yes, well, this is going to be a perpetual problem for people in the civilised world who have a good idea for a product, but choose to get it made in China because you can't beat the price. The quality out of Chinese manufacture is so wildly variable that it is almost impossible to trust it. You might have the world's best quality out of production from Factory A, and you might have it for a year or two, but suddenly, and without warning, your production is moved to Factory B and you don't notice because mostly it's just as good as Factory A. But then the nightshift at Factory B suddenly goes wonky and 50% of your product starts to have bizarre quality problems. But you don't know about it until they start failing in service. If you're not doing quality inspection sampling at a statistically significant rate, you might grab samples only from the dayshift and they all look fine and you can't tell why you're getting failures. Then, maybe you raise your eyebrows to the company doing they manufacturing in China and they respond with "no problem here" while secretly making changes to the back end, and maybe your production goes back to Factory A for a couple of months (unlikely, because they've got some new guy's stuff being made there and he's still on the honeymoon), or maybe the sack the nightshift boss or maybe you get your production moved to Factory C because they suspect that you suspect that things have gone to shit and that you will pull your production contract from them and they start to care even less.
The only way to produce in China is to have your own people there, accountable to you and you only. And that can't happen if you're a small transmission specialist. Hell, my company is massively bigger than these gearbox/diff guys' businesses and we don't have the resources to run our own operation in China (nor anybody from here willing to go live there to oversee it!!).
9 minutes ago, Dose Pipe Sutututu said:
Wow you're right!
Amazing.
If ever you want a good laugh, go read the comments on PRP's Facebook post about the partnership with Speedtek.
  • Haha 1
Got a link, I am keen for some morning entertainment
Bon took me a little while to figure out how to get a link from a Facebook post. Just to clarify the comments are on the original post about them partnering up with Speedtek. Not much love it seems.
‼ NEW BRAND RELEASE ‼ We're thrilled... - Platinum Racing Products | Facebook
  • Like 1
Posted (edited)
My assembler called today and it's confirmed the 2nd Speedtek pinion is in fact toast. He assembled it quickly with the 4.08 final drive to confirm. Worst news is Speedtek isn't answering my emails. I'll give it another few days and then start harassing them by phone.
Good news, my diff should be ready this week. He just had to finalize a few things as he put it to the side for another urgent project (He seems to prioritize funny car/top fuel work). I'm also still waiting on the delivery of another 4.08 S13 LSD diff to take apart this winter to presumably toss in another 3.3-3.6 final drive by myself as to learn. I will not be repeating this experience again.
Aww Speedtek, how I'm unimpressed...
Edited by TurboTapin
If you get a gear set of Neat just be aware that they are a Gleeson cut and need to be setup differently. I know a guy who killed one of theirs in 10 laps because his diff shop set it up like a normal helical cut.
The guys at Neat are very helpful and will explain the differences.
Thanks for the heads up! I'll take a Gleeson cut over a Chinesium Cut that Speedtek uses all day everyday. Jokes aside, for transparency, Speedktek did finally respond and seems ok with a refund. I'll confirm once it's done.
  • Like 3
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
