I picked up my diff today. Both their shop manager and machinist wanted to have a chat prior to me leaving. Conversation started with "Where did you buy these garbage parts? What's the name of the company?" They actually went on Speedtek's website during our conversation and made what I think is the best gear head joke I've ever heard after seeing they make straight cut gears.
"They've probably only gotten away with selling straight cut gears as they'll make noise whether they're properly machined or not. People are none the wiser" The humor made the 2500$ in the hole I'm in after this whole experience a little better lol. They also pointed out that not only did they find identical issues on both ring and pinions that Speedtek had sent, but that by eye you can see the pinion teeth do not have the same profile from one end to the other.
They went on about this being the worst diff job they've ever done and how it was a colossal waist of time. Luckily after mentioning how I purchased another diff to learn how to assemble them, they were nice enough to give me a crash course on diff assembly on another diff they were currently doing. I like to tell myself they did this to be nice but deep down, I know it's to be extra certain they'll never see me there again lol.
Speedtek was pushing for a store credit but I'll never feel confident purchasing from them again due to their third world machining techniques and QC. I just asked for a full monetary refund.
I'll pop the diff back in this Friday and take it for a spin if the streets are clear of snow.
Edited by TurboTapin
  • Like 3
What a major headfk!
I was looking into a Speedtek gearset, after reading your experiences & you pointing out PRP removed them from their website, it's pretty evident to avoid them with the longest pole possible.
You should google "Alex Kantarovski speedtek" and it will lead you down another rabbit hole, with many posts on SAU alone. Alex is the owner of Speedtek.
Someone even went out of their way to create a wordpress site about it. alexkantarovski – Alex K the rip off king (wordpress.com)
  • Haha 1
Great news, diff is on and works well. Doesn't sound like a meat grinder anymore. Going to a 4.08 from a 3.3 wasn't ideal but good enough for now and I'm happy.
Semi bad news, having some DBW issues (P2135). I checked all my connectors, tried adding more filtering, damping, etc. with no luck. I got this error once last year and then it disappeared. I had presumed it had been resolved with a firmware update but I'm not so sure anymore. Either way, I have been seeing some slight voltage drop on my other sensors when fiddling with the pedal. My 5VDC and ground wasn't originally done the greatest (I share both with other sensors). I decided to pull the harness and run shielded wire for my TPS and direct 5VDC and ground wires back to the ecu.
I was already planning on pulling the harness at some point to remove the R32 OEM ECU plug & Elite 2500 adapter harness and just wire it directly to the ecu to help get rid of unneeded junk. It also takes up a lot of space. With more snow on the way, now's the time to get this done.
  • Like 2
Harness is back in the car. Besides removing the Haltech adapter harness and running new shielded cables for my DBW pedal, I also recrimped and soldered all the DBW pedal connector pins. I found another bad crimp on one of the TPS wires. This is the second bad crimp I find on this connector and the most likely cause of my DBW P2135.
While the harness was out, I also segregated all chassis and signal grounds. Nissan bonded both with one wire from the intake manifold chassis ground ring terminal that went back to the signal portion of the ground splitter near the ECU. I'm presuming they did this due to the use of one wire sensors (Ex. Knock sensors).
I'll get the car on the dyno hopefully within the next 2-3 weeks. I need to find a day I can take off work that aligns with the dyno's availabilities.
I'd like to also add that Speedtek has yet to respond to my request for a refund.
  • Like 1
What a prick, the more you look, the worse it gets.
  • Haha 1
I had a mate who was looking at one of their new sequentials they were going to make and when he told me the price my response was “if it sounds to good to be true then it probably is.” Sounds like that’s exactly what it is
  • Sad 1
@TurboTapin I am running a very similar setup to you. I have a CD009 with a Haltech 2500 and iC7. Did you ever figure out a way to get the gear input from the transmission? My r32 gtst does not have abs to pull that data from and I am using a Cusco 4.56 2 way diff not a z diff.
I run Haltech GPS speed.
1 hour ago, TurboTapin said:
Yes, everything works as normal.
I forgot to mention, gear position on the IC7 is a calculation based on engine rpm, vehicle speed and gear ratios you have setup in your ecu.
Interesting. My tuner was telling me that I should not do this when I previously understood that to be an option. Sounds like everything works well for you.
Is the information to set this up available through haltech's website or on the IC-7 dashboard software?
Gear detection can only be done by either the use of a load/position sensor which you generally will not find on H pattern manual gear boxes or calculated from the gear ratio. As we're not running sequential or auto boxes, there are no other options. What exactly did your tuner tell you not to do?
Once you have speed and rpm going into your ecu, all you have left to do is input the correct gear ratios in the ecu. Once you have your speed signal going in, PM me and I'll gladly help you. This is quick to setup.
Because it is, I have calculated gear too.
Only time it shows the wrong gear is when the clutch slips lol.
  • Haha 2
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
