Hey guys.
Have an issue with my r33. Lately (last 2 tanks) has been Randomly pinging/ knocking on boost.
When I first heard it, backed off straight away. Temps seemed fine and was driving fine off boost, almost as it hit full boost, would ping.
Suspecting shit fuel, put in some octane booster, and that seemed to fix it.
Fueled up at a different servo, and was going better than ever, zero knocks. Put it down to shit fuel.
Current Tank is about 1/4 full, rolled on in third coming home tonight and it pinged again.
Car drives fine, and exactly the same everywhere else, no strange noises, temp is fine.
Car has a Vipec plugin, deutchworks 255l/h fuel pump with 14v feed, splitfires, hyper gear turbo, pretty basic setup. 260ish rwkw,  Tuned by Mitch (of haltech)
Car has been the same for the last 2.5 years, parts were new (apart from ecu) at tune time.
Both times it’s happened now, it’s been between 1/4tank and a 1/3 tank of fuel, unsure if that’s linked. Initially thought maybe a shit fuel pump, but thought that would be more consistent
From what I gather the Vipec plug ins don’t have knock protection? Either that if mines not setup.
Will have to head back to tuners I think. I’m guessing if I can hear knock, it’s probably already doing damage.
After first tank with knocking, pulled plugs out (all looked normal) and did compression test, 165-170 across all 6. Top of pistons looked unmarked.
Bloody intermittent issues!
Anyone had a similar intermittent knocking issues/things I should check?
Cheers
https://www.sau.com.au/forums/topic/483055-intermittent-pinging/
On 12/2/2021 at 6:46 AM, Duncan said:
assuming it is not overboosting....
I would change the fuel filter and if possible check fuel pressure under load.
Not over boosting, boost control is setup through ecu, but have a gauge with recall, I’ve seen 21-22psi before. When it pinged, didn’t get there, was around 17psi.
Yep that’s the train of thought I’m on. (Fuel supply)
Will sort out a fuel pressure gauge, I think my Defi meter has provisions for another pressure sensor, will also check voltage getting to pump.
Thanks
If you have oil pressure gauge already plumbed up you have the option of plugging the oil sender port (generally 1/4 BSP) and then plumbing the sensor into the fuel feed to the rail, you would need a T fitting (2x 5/8th barb and 1x 1/4 BSP) which are readily available
On 12/3/2021 at 1:38 AM, Lithium said:
Have you upgraded your CAS setup? There are various options but an aging RB25 and knock on boost has a definite trigger error feel to it
Easiest way to test is try a fixed timing test like 15 degrees regardless of load/RPM, get a timing light on it and see how much it jumps around while you rev. Load doesn't really affect timing scatter.
  • Like 1
Of course not, but knock becomes a lot more likely if you introduce boost to a setup which has erratic timing
  • Like 2
On 12/5/2021 at 4:56 PM, CEF33Y said:
Stock (old!) CAS,
It is very inconsistent. will try the timing check and see what I can find.
Thanks
If the timing check shows timing bouncing all over the place despite commanding a fixed value in the ECU then the most likely explanation is either the CAS drive pin on the cam has worn, the CAS drive gear has worn, or both. I suspect a number of the more severe cases of timing scatter are actually due to this issue.
  • Like 1
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
