Hey been trying to replace this part but not sure what it is called, looks to me like a heater tap but the auto shops never have a listing for one. Is it an actual mechanical part or is it just a hose connector?
Its in the centre of the picture with the 4 hose inlets/outlets
On 12/1/2021 at 6:39 PM, Dontspankmabitchup said:
No shit? So I can just replace it with regular metal hose connectors and be done with it?
I'm pretty sure, but keep in mind 08/1993 to 02/1994 there's a heater control valve part listed as a part of those hose connectors. No idea why and when I go to search up the part number I can't find any photos of it. The english name used is pretty funny so it leads to some jokes on old forums but not much else. I don't know how necessary it is considering how the BCNR33 doesn't have any mention of a heater control valve at all. The BNR32 has a heater control valve that stops the flow of coolant right at the heater core inlet and a water sensor approximately in the same spot as where the heater core bracket is for the R33s. The BCNR33 part diagram for the same parts shows nothing, which implies to me that coolant is always circulating through the heater core.
On 12/1/2021 at 8:32 PM, Dontspankmabitchup said:
Alright ill bypass it and if doesn't blow hot air constantly ill assume all is good. Maybe the constant flow is why the heater cores always rot out... Or to prevent it?
It probably makes the hose barbs that are plastic that much more fragile over time but keeping the coolant circulating is probably a good thing.
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
