Hey guys I been searching for a needle in multiple hay stacks
im try a find parts to do 5stud conversion and manual 5 or 6 speed conversion
question is what can i use from other cars to do this swap parts are expensive but I want to build not buy something done already
also any info on tucked style figment to get the best ride on a daily withou airbags??
I got so coils sourced from bc racing they make a setup specifically for the guys 4 as you need the front and gts(t) in the rear as far as wheel and tyre size and other components to make this happen I’m a newb 🤷🏽
any help please
https://www.sau.com.au/forums/topic/483065-r33-gts-4/
On 07/12/2021 at 9:20 PM, Kozo4r33 said:
So many times so much info on here it’s hard to find especially not actually knowing what I’m looking for some of the threads are over 10 years and questions weren’t answered
So you've found a bunch of info, or you found nothing? You're not being clear. It seems like you have a lot of reading and searching left to do.
You need to ask specific questions for people to help you. If you haven't found answers to your questions, then it's likely that no one else has done it and you'll be a pioneer.
https://www.sau.com.au/forums/topic/483065-r33-gts-4/#findComment-7958520
Is the 5 stud conversion just to pretend that it's a turbo and not NA? Because there's not a lot of other reason to do it on an NA Skyline otherwise. It's not as if you can't get wheels to suit. It's not as if you can't do bigger brakes on the 4 stud either.
I would have thought that the answer to the question "What other cars can I get bits from?" would be obvious. The 5 speed manual from the manual version of your car, and the 5 stud parts from turbo R33 Skyline.
As NiZmo suggests, these exact questions have been asked and answered on here hundreds of times (if not thousands) over the 20+ year history of these forums. Nothing is new, everything is old.
Also, nowadays, finding the parts you need is almost impossible. You will need to scrape and steal to get the full set of things you need. You will likely end up buying 5 parts cars. In fact, if your car is physically in great condition, you would likely find the best way to achieve your goal is to literally buy a car that has the stuff you need on it, that has a shit body/paint or is defected, or damaged. If you can find one.
https://www.sau.com.au/forums/topic/483065-r33-gts-4/#findComment-7958524
The 5 stud conversion is to learn brother I’m a amateur at this stuff I want to learn never built a car before eventually if it presents itself i want to turbo the car it’s gonna cost a bit I’m not fazed by that I’m not rich and it might take longer but I wana say it was built not bought
https://www.sau.com.au/forums/topic/483065-r33-gts-4/#findComment-7958806
Yeah that's fine, no problem with wanting to work on your project car. Just remember to deep dive into this site, there are many many pages of information that is relevant to whatever you're doing. Just remember parts will be harder to get these days, so research is critical.
https://www.sau.com.au/forums/topic/483065-r33-gts-4/#findComment-7958821
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
