Anyone used any of these ??
There this Aussie one - from Tech edge
http://wbo2.com/
AUS $490 in kit form
AUD $700 pre built
(included Bosche WB O2 sensor)
There's this one - LM-1 Air/Fuel Ratio Meter
http://www.innovatemotorsports.com/lm1.php
US$349
Then there's the TurboXS one
http://www.turboxs.com/Tuner/tunerfeat.shtml
$US549
OR has anyone else had experience with other brands ?? (inexpensive ones - not the $1500+++ Motec etc ones)
Cheers,
https://www.sau.com.au/forums/topic/48307-wideband-afr-meters/
Would I be correct in saying that you would have to use these as a tuning tool only if you have a standard ecu?
What I mean by that is that you would have to have two o2 sensors? The standard one to do its thing with the ecu and the wideband one just to view your air/fuel ratio?
Because a wideband sensor will not work with a standard ecu. Well it dont work with mine anyway, I run without a o2 sensor fitted at all.
Ive got an older type bosch lambda metre that i use for circuit racing and find it a great source of information and a long with an oil pressure guage would be a must have in big doller skylines being used on the track . Definatly saved my EJ20 when the fuel pump was about to die as the mixtures started to lean quickly and i just took my foot out of it. Word of caution however only the big doller ( ie motec) sensors have heat correction as i found with mine after 3 laps it heats up and reads a leaner figure but as soon as you cruise it for half a lap and reapply the throttle mixtures are correct again .
adam
adam
Sadly Motec=pricey.
One thing which i wouldnt be too concerned about is if they have temperature compensation. Great if they have it but word of mouth has it isnt critical for accuracy.
This idea didnt go down too well, http://www.skylinesaustralia.com/forums/sh...highlight=money
i have the lm1 type from the usa... have compared it to the dyno af metre and its pretty dam close.....i would have no worries about tuning a car with it .. safe as all the other more expensive ones... has datalogging and good software....
cheers...
at present just its own datalog ... i believe datalogit is hard to get all the settings right between the two units.. going on what people on the datalogit forum talk about...
but lm1 is pretty cool for the price...
my car runs 11.8 af on the dyno and the same on the road with lm1 in the tail pipe....
so i am happy..... and its fast acting about 10 or 20 times per sec i believe...
the only thing i dont like is the small lcd screen but if you have a laptop its no worries...
cheers....
hi there, I brought, built and use the techedge meter. Its very good, very accurate (compared to the high speed AFR on a dyno dynamics dyno (in fact it uses exactly the same bosch sensor)) and I run it into my PFC datalogit program. Its awesome and allows on road tuning and full datalogging of all your runs :P When used with the datalogit program of course.
I would highly recommend it
MIke
  • 6 months later...
GRID, Inc.
*Distributor*
4-20-16 Igusa Suginami-Ku
Tokyo 167-0021
Japan
03-3301-3047
03-3301-8470 Fax
www.grid.co.jp
NZ Performance Wholesale Ltd.
152 Highsted Road
Casebrook, Christchurch
New Zealand
03 360 3004
03 360 3009 Fax
Rice Racing
New South Wales
Australia
0402 464 245
thats what i found on the website.
the older wbo2 wideband controlers had to be manualy callibrated from what i can gather off of the website but the new ones are spot on now with the big money ones.
ive got a friend who tuned his car with one and then dynoed it and afr's were spot on, ive one on the way here stateside for my car when i swap the rb20 in.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
