Hey everyone I know this has been discussed many times in past. I have gone through most of write up in regards to solving this.
So my steering goes light to heavy after 1min or so of starting to drive.
Little background — My hicas is deleted other than the wiring and HCU, i.e rear Hicas pump, lines, rack is deleted and fitted with lock bar in rear.
That said, I have checked everything wiring related and it is all hooked up— other than below,
Questions ?
Will not having a steering angle sensor (behind steering wheel) cause this ?
Is there a pin on the ecu talking to hicas ? If yes which pin ?
I am aware pin 53 is speed wire from speedo, which is getting feed from speedo in my case.
HCU itself seems to be working as if I disconnect it, my steering goes heavy from the start. It seems something is causing it to go in fail safe mode.
I don’t have hicas light on dash so haven’t done the self diagnose yet.
Also does the nissan consult port gives you hicas related codes precisely ?
I am in located in Brisbane if anyone can help with the consult tool or point in direction which doesn’t cost kidneys.
looking forward to hear from you absolute legends out there 😘
https://www.sau.com.au/forums/topic/483085-r32-power-steering-lightheavy/
No, but you should need to have the smaller of the 2 plugs in the HCU pulled out to avoid the absent sensor (and the absent all the rest of it!) causing the HICAS system to go into fault and raise the dash light.
Not that I know of. Break out the new scan of the wiring diagram that I posted up a couple of months ago and trace every wire from the HCU, just to be sure.
Yes, with a proper workshop grade diagnostics handset. None of the Nissan ECU code pullers will talk to the other CUs on the bus.
The HICAS CU definitely controls the power steering solenoid. The 25+ year old age of these cars has meant that the looming death of these CUs has been hanging over our heads wrt keeping the PS working properly.
The solenoid just gets a PWM voltage signal to vary the assistance, mostly with speed. It should be possible to fudge something up with an Arduino when we get desperate.
  • Thanks 1
On 11/12/2021 at 12:17 PM, GTSBoy said:
Also, it could be the solenoid crapping out. Could have a bad connection in/on it that gets hot and gives up, or something more weird. Try putting 6V or so on it directly and see if you get consistent operation.
While I do this temporarily to know working of my ps solenoid, should I just disconnect both plugs at the HCU ?
On 11/12/2021 at 12:16 PM, GTSBoy said:
Can you please put a link to it here, I saw it when you first posted it. Can’t find it now.
Nissan Datascan will pull HICAS codes and allow you to run HICAS active test. I plan on running that instead of whatever this magic Konami code thing is: https://www.importavehicle.com/blog/hicas-four-wheel-steering-self-diagnosis-procedure
@GTSBoy
Also out of curiosity, do you know what will be the effects of deleting the solenoid off the rack and getting steering shop to blank it ?
In that case its just running off the SP and hicas can be completely taken out of the story, but has only done this before ?
Also pin 19( PS idle up ). Is it linked to the pressure switch on lines going to rack ? Is it there just to tell the ecu to rev a bit on full locks ?
On 12/10/2021 at 8:37 PM, Rb25orange said:
@GTSBoy
Regarding PS idle up that is the purpose yes. When the power steering pump pressure spikes because of full lock or low speed maneuvering it will drag the idle down otherwise so the signal is there to tell the ECU to bump the AAC duty cycle significantly. One of the few things Nissan did right was making that system electronic, on a lot of similar era Toyotas it's a purely mechanical valve and it's notorious for failing with age at which point your intake starts sucking a lot of power steering fluid.
Edited by joshuaho96
Appreciate that info man, definitely helps sorting some other issues I have been having with idle dropping coming to stop.
Atleast I am clear that switch is not bothering my hicas.
I will be doing continuity test for my hicas wiring over the weekend, and update.
thanks
Very very heavy steering. You need at least some (minimum) voltage on that solenoid to gain assistance. I think a flat voltage would probably feel bad. That's why I'm leaning towards an Arduino type solution for those that need to replace the HICAS CU's duty.
I'm not sure what you mean by this. I don't have one. My bro-in-law is a machanic and has such a unit so I've plugged that in in the past to interrogate the steadily decreasing list of other CUs in my car (TCU is gone, HICAS is now neutered, ABS?TCS has been shaken loose from the NEO ECU's grasp).
You can use Strap-On brand, or any of dozens of other workshop grade diagnostic scanners. Just can't afford to buy your own - have to borrow.
Oh, was your quote of my post messed up? In which case, were you asking for a link to my post with the workshop manual scan? Um.....I dunno, hold on while I look....
here
Sorry for my confusing jargo man, Yes I meant the link to the diagram/from previous post of u’s.
Definitely can’t afford one atm, I have my whole rear subframe stripped atm, so thought I will bell out all the wiring for the hicas while at it.
Have checked my speedo wiring and sensor that all ticks out but I am yet to check pwm at speed signal going to pin53 to be 💯
thanks, much appreciate your help.
There's no need for an expensive diagnostic unit to check for codes/active test the HICAS system. Nissan Datascan and a PLMS Consult cable will do great if you have an old laptop lying around somewhere:
Nissan DataScan I
Does this flow chart describe your issues?  Where your steering became heavy after a few minutes of driving, but it returned to being light after you restart?  This came off the gtr manual, not sure if it applies to others but hopefully it helps.
  • 3 weeks later...
That definitely helps man, not to sure though how to test if speed signal from speedo is getting to the ecu (pin53). I am sure a normal multimeter doesn’t have a option to see pwm signals. I guess I need one that measures pwm signal and check at the wire to pin53.
however on previous diagnoses I know the sensor is in place behind the speedo and wire from there to pin53 is continuous.
@GTSBoy Input please, correct me if wrong, also is there a way to see speed signal at the wire to pin53 to see if the signal is generated at all ?
Also from previous conversation, I wanted to know how is the ecu talking to hicas, as the only wire I could find out goes from hicas to ecu. So how does hicas know what assistance is needed if signal from speedo is going straight to ecu and from there to where ? With the diagram I have I can pin8 at the bigger connector of 2 on hicas is controlling the steering rack solenoid, but not sure as said how is hicas getting this
info ?1AAC5C8A-C8AD-4305-BBD3-C9D7D0745250.thumb.jpeg.472234f2bfe6f1ccb94dfd54f7fadd51.jpeg
  • Like 1
I haven't looked at the wiring diagram that closely, but I think the speed signal is available at the HICAS CU also.
As to how to "see" the speed signal....with a consult unit you can see what the ECU thinks the speed signal is. If you want to look directly, then you need to tap the wire with a CRO. You can buy cheap CROs that are USB or wifi these days that you can use with your computer or phone. Worth having.
  • Like 1
  • Thanks 1
  • Like 1
Yes it does, it concludes my issue is PS solenoid related, my solenoid itself is working though as I wired it yo 6v for time being and it is working but do want to fix it properly as its light all times and doing sharp turns on higher speed (60-70) it feels out of control and tried 4v it feels weird at that level. So yeaa would be nice fixing it properly. Specially when I know it can be done.
  • Like 1
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
