Hey folks, I'm in a bit of a pickle. I just bought a 33 GTR about a week ago. Fairly basic car (mods are PFC, exhaust, boost, front mount). I filled up as soon as I bought it and was driving it around for a few days and everything was good.
I then filled up again a couple of days later and after I got in the car there was a strong petrol smell the whole way home. I thought I might have stepped in petrol or something so I chose to ignore it. Next day, jumped in and it didn't smell that bad. Went for a drive and the smell disappeared. Then, all of the sudden the smell came back and it was strong! I checked the engine bay, no leaks. I checked under the car, no leaks. I took the boot apart to see if there was petrol or anything at all, no leaks. I'm stumped! I read up online that it could be the seals on the fuel pump but wouldn't that mean that the smell would be constant?
Any advise on where to start would be greatly appreciated.
https://www.sau.com.au/forums/topic/483089-car-smelling-like-petrol-r33-gtr-s2/
@GTSBoy I'll have a look when I go downstairs again but even if it's removed wouldn't the smell be coming somewhere from the engine bay? I'm like 80% sure it's coming from the boot near fuel pump area.
@PLYNX the tank is definitely not pressurised. I noticed that the first time I went to fill up and every time I open up the tank since it's just twisting off super easy. No pressure at all. How do I access the fuel filler neck?
@Duncan Sydney. After the last comment, I'm starting to think it's the issue with the fuel filler neck. Advice on next steps?
On 13/12/2021 at 8:13 AM, Mlads33 said:
Also @Duncan I've tried adding info to profile but keep getting EX1364 error - am I f**king something up or...?
@PranK over to you :)
Back in the olden days, an unleaded fuel restrictor had to be fitted into the filler neck to stop you putting leaded fuel in (even though that hasn't been available for about 20 years). Compliers would stick the restrictor in with silicone and it often wasn't fuel safe so they would degrade over time.  You can check for all of the fuel sealing issues by parking it in the sun for a few hours, then opening the filler cap. If it doesn't release some pressure you have a leak in the system which could be
Fuel cap
Filler neck seal/unleaded restrictor
Fuel neck to tank
Fuel pump lid or seal
Carbon cannister system (should seal unless engine is running)
Thanks @Duncan! I've got a big feeling it's the fuel neck to tank. When I open the fuel cap, there's like a 5 cm separation from the neck to the cap. Now, I'm not sure what it's meant to look like on R33s but it seems to me like that's meant to be flush against the cap.
If this is the issue? Any tips on how to go about fixing it?
Could be anything from anywhere. That's the problem with carbon canisters. They are such simple things in concept, but there are so many ways for morons to interfere with them so they don't work properly.
  • Like 1
On 13/12/2021 at 12:55 PM, Dose Pipe Sutututu said:
Or could be the seal where the fuel tank lid goes, perhaps whoever changed the fuel pump in the past cocked up the installation.
A good chance it's this, you really notice it if you fill it up
  • Like 1
Mate, this sounds very promising. f**kin' reeks as soon as I fill up then dissipates over time. Just to be clear - seal on the inside, not the cap itself?
Hope this helps :)
https://www.efisolutions.com.au/fuel-tank-seal-s14-s15-r32-r33-r34-wc34-c11-t30-t3
It sits between the tank and the fuel tank lid (whatever it's called) followed by a locking ring around it. Can be a CNUT to take off with out the tool, but a piece of wood and a small hammer gets it off pretty easy. When re-installing I suggest some form of lubricant like lithium grease or KY lolol
  • Like 1
On 13/12/2021 at 12:43 PM, Dose Pipe Sutututu said:
Hope this helps :)
Thanks man! I've just ordered the part and will start ripping shit out this weekend. Any tips, tutorials, or anything else you can point me to?
Just search for a fuel pump change tutorial or post here.
Should be the same (minus the fuel pump swap)
  • Like 1
On 14/12/2021 at 11:37 AM, tridentt150v said:
very affordable too, should have looked into something back then lol... I grazed my knuckles and lots of F & C bombs were dropped LOL
  • Haha 2
  • 4 months later...
Just an update in case anyone is interested...
I ended up getting to the fuel pump and the cap was essentially welded on. The person that worked on the car before was definitely doing something there because when I managed to get the cap off, the seal that was meant to be there was just thrown into the petrol tank. Literally - just floating around in there. No signs of damage or wear at all. The bloke would've been having a shit day and just decided "screw it" and thrown the seal in the tank.
Put a new seal on, pieced everything together and the petrol smell was gone. Thanks everyone!
  • Like 5
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
