Does anyone have a 34 GTT manual speedo i could to test with?
The speed cluster on my instrument stopped working at the end of a drive as i turned into my street and dropped to 0 (it never fluctuates or moves at all).
everything else is OK, RPM, fuel, pressure.
Tried holding the clock reset in (as seen on another post), i have replaced the speed sensor from the gear box and checked the plugs on the gearbox also.
Am hoping someone may have a speedo i could plug in to confirm that is where my problem is?
https://www.sau.com.au/forums/topic/483121-r34-gtt-speedo/
Not aware of the cog? Assume i need the box out for this?
The continuity test was why I wanted to borrow someone's cluster to test with, if speedo didn't work then something like the cog or no signal prior to the dash.
Figured this would be the last thing I could check before getting it looked at by a professional
https://www.sau.com.au/forums/topic/483121-r34-gtt-speedo/#findComment-7958942
Well, gears don't drive themselves.
Inspection camera?
Multimeter?
https://www.sau.com.au/forums/topic/483121-r34-gtt-speedo/#findComment-7958943
Yea I didn't mean fundamentally how it works just not the cog you are referring to.
Don't have an inspection cable or a multimeter. Or the knowledge of what to look for
Hence why I'm looking to test with another cluster (if possible) as a last thing I can do on my own before going to a professional. If another cluster works problem solved if not, ill wait for my mechanic to have availability for me.
https://www.sau.com.au/forums/topic/483121-r34-gtt-speedo/#findComment-7958945
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
