Is this on anyone else's santa list?
Modifications list:
Performance
Power (bhp): 355 + 75hp for N20
Torque (lb-ft): 315
0-60: 4.9
1/4 mile: 13.3
Top speed: 155
Engine
Exhaust: MagnaFlow
Supercharger/Turbocharger: Coming soon
Drivetrain
Transmission: SMG sequential manual
Axle(s): IRS
Brakes
Rotors: Stop Tech 14 front and rear
Calipers: Huge Red calipers!
Suspension
Lowering Kit: KW Version 3
Shock(s) / Strut(s): KW coil overs
Sway Bars: Hotchkis
Misc.: Fully adjustable ride height
Wheels/Tires
Wheel Manufacturer: HRE
Wheel Size: 20 x 9.5 front, 20 x 11 rear
Tire Manufacturer: Continental
Tire Size: 255/30 R20 front, 305/25 R20 rear
Exterior/Chassis
Paint: Candy blue
Ground Effects: Flosman widebody kit
Bumper(s): Flosman
Lighting
Headlights: HIDs with Angel Eye halos
Turn Signals: Stealth bulbs
Interior
Dashboard: Carbon fiber accents
Gauges: Motec racing display
Pedals: Carbon fiber
Seats: Sparco
Electronics
Head Unit: Clarion VRX935DVD
Radar Detector: Passport, built in
Dash Speakers: Infinity
Front Door Speakers: Infinity
Rear Deck Speakers: Infinity
Subwoofers: JBL W12GTi
Subwoofer Enclosure(s): Custom built
Front Amplifier: JBL P80.4
Rear Amplifier: JBL P1200.1
https://www.sau.com.au/forums/topic/48314-430hp-widebody-m3/
You could always custom turbo it, and give it more power. You got to remember its only a M3 not a HIGH Performance car.
Uhh... a M3 isn't a high performance car? Then what on earth is?
Adrian, I don't think its been designed as a drag car :rofl:
https://www.sau.com.au/forums/topic/48314-430hp-widebody-m3/#findComment-972427
i think it should be doing more than a 13.3 more like mid 12's for the fact it has nitrous as well. I'm pretty sure a new stock m3 can do mid 13's or so.
I agree,
Engine M3 Convertible
Cylinders: 6
Valves: 24
Capacity: 3246 cc
Maximum Power: 252 kW / 343 bhp / 7900 rpm
Maximum Torque: 365 Nm / 4900 rpm
Acceleration 0-100km/h: 5.5 s
As you can see, not much HP between Uber's and the Factory, besides the N20... So the only thing i could think of is the speaker system brings the weight up, put the extra Hp and N20 brings it back down to the factory runs.
Well who cares Quote: Supercharger/Turbocharger: Coming soon
https://www.sau.com.au/forums/topic/48314-430hp-widebody-m3/#findComment-972462
Guest RedLineGTR
i would say it looks okay...but i like the m3's nice and stock they come with a pretty good package for a stock car with the price tag.
with this image
It think it looks like they have been trying to hard...to make it look fat just for the sake of it, rather than make it look better.
https://www.sau.com.au/forums/topic/48314-430hp-widebody-m3/#findComment-972466
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
