Welcome to the club Hope you enjoy your skyline make sure you always put the highest grade gasolene without ethanol in it change oils at regular times i change engine oils every 5000kms gearbox diff every 12 months as well as power steering fluids and brake fluids dont sit on the rev limiter have fun
    • Holy hell! That is absolutely stunning! Great work!!!
