Does anyone here have any picture examples of locations on the firewall they've run a circular bulkhead connector like the Corsair/Amphenol units commonly referred to as "milspec", or Deutsch AS connectors? After looking around a few times, it seems like all of the good space is right behind the ABS module, but with no room to connect and disconnect them as it's pretty tight? Anyone have any other ideas on a car that will retain AC and heat?
I’ve only just got my 2 connectors (47 pin deutsch) so haven’t done it yet but my plan is to replace the factory grommet with one and putting another one just below the brake booster on the drivers side.  I’m running drive by wire so will need extra wiring in that area so makes sense to relocate some of the wiring across that side at the same time.  My aim is to have no wiring across the back of the firewall at all (would like to take coil wiring across to drivers side loom as well) but we’ll see what happens….
which car, your profile and post don't state?
I've added a grommet and wiring through for brake pressure sensor next to the ABS which is a similar size to most of those circular connectors in my 32 gtr
I'm on mobile now, so I can't see my profile. I thought I had it on there, but if I don't it's an ENR34.
Looking to run 3 circular connectors. I was thinking someone may have utilized some space on the lower portion of the firewall that's not incredibly obvious from above.
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
