On 03/01/2022 at 8:40 PM, GTSBoy said:
Am I the only one that noticed that both the pistons and the rods are listed (in the OP) as being to suit both RB25 and RB26? Given that the Neo25 uses RB26 rods to go with the unique Neo25 pistons, it would seem quite reasonable that CP and/or Manley would have one part number that could be used on either a 26 or a Neo25.
OP, you are worrying about the wrong things. Follow advice above. Then start wondering why they are not telling you what the plan for the oil pump and/or drive is, why there's no mention of the head, gaskets, timing belts, water pump, etc etc etc. Ask them about those things and listen for a confident response. If the response is not confident, you will likely need to go elsewhere.
On 03/01/2022 at 5:10 PM, ASTRO_GTR said:
See how it says in red will not work for rb26, this is because of the pin height, rods are same length so can be 25 or 6, you have the same block with same rod length but a bit more stroke on the crank so the different pin height
