Lost a Nismo center cap off my wheels god knows where.
Made up these as a replacement !
Bloody Covid lock downs and staying away from everyone made me do it !
Original in chrome was silicon molded then cast in polyester resin.
Then the Nissan center section machined out.
A silicon mold was taken off a small Nismo aluminium badge and that was also cast in polyester resin.
The two were stuck together and Bobs your Uncle . . . . . but not if he has the operation cause then he would be your Aunt ! ! !
  • Like 1
https://www.sau.com.au/forums/topic/483165-wheel-cap-centers-nismo/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
