got done :(
coco69
 Share
hey guys,
finally it happened. got done for power/weight as well as defected. im gonna need an engineers certificate. can anyone recommend a good/cheap and reliable place to get one done?
also, with those of you out there who have experienced power/weight, do i just have to pay off the fine and im clear? (that is, just wait till i get another one.)
thanks guys.
and vic cops :cuss:
Guest RedLineGTR
power/weight you just pay the fine. They may hassel you abit if they pull you over again as i guess they would have all things on record...isnt a r32 gtst legal for the power/weight rule?? i though r33 gtst were the problem??
Guest RedLineGTR
i myself at 2;30pm got done by the victorian police force. for speeding. my own fault and i dont bitch about it just about the $205 dollar fine which is smaller to what i should of got that night. I guess i'm lucky as well, 2 some extent on what became of the situation. I'm on P plates as well..
hey rob, that was a quick reply!
nah i got done coz of my non-standard engine... :rofl: so not only just a defect, but i gotta produce an engineers cert :rofl:
common enough for me, 8am sunday morning on my way to church, cruising 60-70 down stud road, scoresby. usual light traffic around me, i see this crazy silver xr6 cut and chop through the lanes to tail me. next thing i know, lights flashing as i'd just done a drive-by. hmpf! and greeted by everyones favourite officer.
Guest RedLineGTR
"non-standard engine... " ey....what is it pink???
Coco i still have you dam copy of initial d!!!! when i'm around your area i will give you a buzz and drop it off, its been too long!!! and i havent been around your area for ages..if your number still 0412 808 ETC... if so i'll call you and drop it off soon!!.
is it an rb20det ?
Probationary driver licence holders must not drive high powered vehicles. A high powered vehicle is any vehicle with a power to weight ratio over 125 kw per tonne, or with an engine capacity to weight ratio over 3.5 litres per tonne.
Capacity to weight ratio is the capacity in litres divided by the weight in tonnes. Power to weight ratio is the power in kw divided by the weight in tonnes. In doing calculations, weight is specified in tonnes (1000kg = 1 tonne); capacity is specified in litres (1000ml = 1 litre); power is specified in kilowatts (kw) and is as measured at the engine flywheel.
The weight of a vehicle is the unladen mass specified by the manufacturer for the stock-standard vehicle (without options). Since 1988, this weight is specified on vehicle data sheets, as published by the Commonwealth Department of Transport and Regional Services. Vehicle manufacturers provide the information used to prepare the data sheets.
The file attached below contains a guide to vehicles that are classed as high powered motor vehicles. The Guide only covers standard vehicles that have been made in Australia, or imported in bulk, since 1970. It does not include all high powered motor vehicles. If you are concerned that a model not included may be a high powered motor vehicle, then you may be able to get engine power and vehicle weight information from the manufacturer.
If your car is modified, you may also need to obtain an engineer's certificate and do your own calculations. You are also required to notify VicRoads of any significant modification. Penalties for not doing so are severe.
If you are a probationary licence holder, it is your responsibility to make sure any vehicle that you drive is not a high powered motor vehicle. The penalties for driving a high powered motor vehicle include a heavy fine, and may result in licence suspension.
Engine Code RB20DET
Engine Type Inline 6 cylinder DOHC 24 valve IC turbo
Engine Size 2.0 litres (1998 cc)
Max power 158kW @ 6400rpm
Max torque 265Nm @ 3200rpm
Forced Induction IC equipped turbo
Weight 1320kg
So:
158 / 1.32 = 119.69696969696969696969696969697
So yes according to factory specs you can drive an r32 GTS-t Type M on your p plates.
I think those figures are correct, feel free to correct me if its wrong. The
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
