Should I pressure clean carpet mats and boot lining?
I'm guessing you mean something like this size? https://www.supercheapauto.com.au/p/bodyworx-bodyworx-hard-soft-sanding-block---70-x-135mm/594184.html?cgid=SCA01100303#srsltid=AfmBOoq_qZTEe3boann9BaHiB2f59dxJlosWLzCr0zm_weHgUlDX-N5f&start=6 Are they sanded completely flat? -
Just a standard sanding block size. With the rock chipa they are quite small. I sanded them as you could feel the edges.
Say you've just laid all your filler and your about to start sanding, how large is the sanding block your using? Like a high fill primer? Technically possible but would be a nightmare. Just guessing from the photo, but they look small enough that you might get away with using a 1k spot putty. Normally you'd use something like this on pinholes but with the type of project you're working on I'd give it a go. -
I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
