Once more I have come to lap at the font of knowledge 🙇‍♂️
So, continuing to trawl most corners of the net in search of parts to build a complete RB26/30 from relative scratch. Have found a used cylinder head that has come off a 93 GTR.
Seller was upfront about history, which is always a good sign. Head came from a mates car, which was a tuned low mount double jobby putting out around 400hp? He was not sure on power. Engine suffered some sort of failure, but lost oil pressure. Said he took the head to have it looked at, and the guy (from head to head in clayton if that helps) said it needed work but could be saved. I'm going to get into contact with the repair shop who hopefully remembers the head in question. But otherwise will pay to have it looked at by a shop to get another appraisal of the head before paying for it, especially since its in Melbourne and I'm in Perth.
Now, I'm no mechanic but if the engine is starved of oil the parts that rub together get a bit sad. So I'm guessing the camshafts, the camshaft caps and the journals will need some machine work? Buttttttt, If I don't plan on using the OEM camshafts and plan to go for an aftermarket set, I would need to get the camshaft housings line bored anyhow? So it might not be that big of a deal? What are some of the other problems a cylinder head might suffer if it has run out of oil? 🤔
Included are photos for refrence.
Cheers
Yeah, I'm gonna hit him up for some closeup photos of the journals/caps.
Its at a decent price, especially since it has all the required parts for a complete cylinder head, minus the passenger rocker cover 🙃
I thought the same regarding the head not having oil. Its a camshaft, not a crankshaft? Surely the forces would be small enough that they couldn't do that much damage...
You really need to know the machine shop's quote to fix it if you are going that way.
The head is easy to hurt more than the block from an oil issue because the cams are steel, running in an aluminium head, withhout bearings in between...it can get chewed up pretty quick.
Fitting cams you never need to machine the cam tunnel, so don't talk yourself into thinking that is a cost you have to pay regardless. The machining for cams os clearance for the lobes, the tunnels are untouched.
Fixing f**ked cam tunnels will cost a lot. Get a quote for that.
I wouldn’t go near it, there’s a reason he’s left the cams in, the 3rd journal on the intake cam is stuffed and the 1st, 2nd journal on the exhaust are pretty bad and the 3rd and 4th aren’t far behind them
  • Like 1
  • Thanks 1
Im sure the head can be repaired but it not just a simple close and hone of the journals and caps the head will have to be stripped alloy journal areas will have to be welded and built up then if all goes well will have to be machined new caps cams guides possible valves lifter buckets it wont be a cheap job i hope for your sake you have very deep pockets. I would be looking for another head i think it would be much cheaper try Lewis engines see what they might have or can do for you they did my head and it wasnt damaged like the one your looking at and my head cost me over $5000.00 seven years ago
Resolution to the question.
While still waiting for those closer photos of the journals/caps, I got into contact with the guy from the repair shop, and he outlined pretty much what Brett/R32-25t said, though in a very diplomatic manner 😅 Head is not worth the money seller wants, maybe only worth as a very cheap experiment to someone with the means and the time to try something crazy on.
A bit more to the story, but another case of making sure people should do their homework before buying anything second hand, and again making me very grateful this site exists.
Edited by Diomedes
  • Like 1
That is correct Dasmbo, the machine shop that examined it said few journals would have to be welded and built up, then machined back. The damage had the machinist questioning the integrity of a few of the cam cap retaining bolt locations...
Basically said if it was a Ferrari, sure, the money and time would be worth it. Not for an RB26 head.
  • Like 1
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
