On 26/01/2022 at 6:03 AM, Bigpad said:
Well I bought a pink label MAF off a low mileage r33 spec 2. I’m told they’re the same? Plugged it in and started the car. It fired and ran just fine (I didn’t take it for a spin as it’s cold and dark and I haven’t done up all of the hose clamps or brackets).
However, despite the car seemingly running fine all of the dash lights are still lit up. I won’t know how she runs for sure until the weekend but I’d really like to get those dash lights sorted? Any help or advice would be appreciated! 👍
Also….. Is this what I need:-
and then download the data scan 1 software?
thanks again. 👊
I have that same unit. Works very well with my laptop via USB running Windows 11.
So I’ve taken the car for a bit of a drive. It starts and drives just fine. I still have the dash lights on so have bridges the two pins on the diagnostic port. I’m getting code 21 which from what I’m reading is suggesting a coil pack issue. I’ve obviously done the coil packs, spark plugs, MAF and CAS. That doesn’t rule these out of course but the fact that the car starts and runs fine suggests they’re all good. Bridging the pins further and shutting the car off has not gotten rid of the warning lights!
Any help/advice would be appreciated.
Code 21 means the ECU isn’t seeing the right resistance on one of the coilpack primary side circuits. I got it once when my ignitor unit had a slightly loose connection.
On 1/31/2022 at 3:32 AM, Bigpad said:
The R34 doesn’t have an igniter unit does it?
could the issue by the coil pack harness?
R34s shouldn't, but the logic is the same. The ECU sees the primary side wiring from the ECU output all the way out to the coilpack pins and back to the ground point. If it sees open circuit it sets a code 21. Short circuit you would probably detect pretty rapidly regardless of whether the code is reported or not.
That's true of the R34s, but only inasmuch as it is also true for engines with a separate igniter. The ECU is not actually connected to the coils at all, on any of them. It is connected to the igniter. So the ECU's diagnostics on the "primary side" is actually only to the transistor that is the igniter. True for both older separate igniters and for integrated igniters.
The ECU does not see the primary coil of the coilpack.
Good to know, when I was thinking about this issue for a while I had a feeling that was the case but I checked all the connections from the PTU to the coils anyways. My circuits professors are probably shaking their heads right now.
  • 4 weeks later...
So……
Ive been able to plug the car in but don’t really know what I’m doing. I was able to isolate each cylinder in turn and the car behaved as I would of expected. Reset the ecu via the laptop but all warning lights stay on.
Ive now replaced the coil pack harness as I wanted to rule it out but still no joy. The car is running ok but it seems to have a ‘stutter’ every few seconds on tickover.
Can anyone advise as to where I should be looking next? It’s really bugging me now.
Thanks.
I think you've changed the spark plugs, coil packs and coil pack loom so far? Which coil packs did you install? Can you swap the best of your original coil packs in one by one and see if you can identify one of the new ones is not OK? Also, what plugs did you install?
Also, you've mentioned it has a miss at idle. How does it run for normal driving and at full throttle, is it smooth or does it still break down?
I'm assuming the issue is on the spark side since that is what you got from the ECU....but of course it could still turn out to be a fuel or timing issue
On 3/1/2022 at 12:47 PM, Bigpad said:
So……
Thanks.
When you say stutter every few seconds do you mean the idle dips and recovers? If so make sure you are 100% sure you can trust the provenance of your spark plugs. I have gotten counterfeit ebay spark plugs before and while it mostly drove normally I noticed that at idle it would stumble and then catch itself cyclically. I have no explanation as to why that happened but replacing the spark plugs with OEM plugs sourced from a trustworthy source the engine ran normally again.
Does the ECU report any codes when you check via the laptop? You're going to have to figure out whether the control module is actually reporting error codes that should cause the warning lights to turn on or if it's something wrong with the cluster/wiring harness.
I bought all the replacement parts from reputable companies here in the uk but you’re correct, that doesn’t rule them out as still faulty.
does the ecu report any codes you ask? Hmmmm that might of been some valuable info to include. 🙈🙈
I would start looking for line breaks in the cylinder 1 injector circuit. That's a pretty simple circuit to follow. It is very strange to me that your engine runs at all with that ignition circuit code, when I had it my car straight up would not crank over at all. It's possible that it will go away if you clear it but if it doesn't you probably shouldn't ignore it. The other mystery error codes are kind of concerning, not sure what's going on there. Could be a lot of things causing it.
  • 3 months later...
Well the saga is over. I bit the bullet and bought some splitfire coilpacks. While I was fitting then I replaced the cold NGK plugs I’d fitted for ones recommended by a member on here. Started the car up, the dash lights are off and the stutter is gone. Thank f**k!
thanks to everyone who commented. I really appreciate the help.
  • Like 2
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
