Hey all, need some insight please on what I may have done wrong on my install
Finally got around to installing my shift-kit on the weekend and it was pretty straight forward
I kept everything organised, followed the instructions to the letter and kept an eye on the ball bearing and filter placement
Found another DIY from the G35 forums which recommended flipping the valve body over to keep the upper half separate with (in my case) 5 balls and springs since all the work is done on the lower (also double-checked the holes to be drilled out)
Put everything back together and took it for a drive but noticed it wanted to keep bucking down to 1st when in 2nd at medium throttle
Figured there may have still been air in the lines so slowly went through all the gears in manual mode and did a few light pulls in D
Everything seemed okay so I drove it home but noticed when it got hot it kept either trying to select a lower gear and bumping back up (when in D) and I now get an even worse jolt in 2nd where it seems to not be able to make up it's mind whether to drop back to 1st or stay in 2nd resulting in a really aggressive jerk
I've focussed on the fluid level to rule that out as it may have been overfilled after the install
It's all okay now but I still have the issue with it bucking in 2nd
I have no problems with pulling it all apart again but not sure what to look for
I also noticed a weird issue where the P will disappear from the dash when putting it in park sometimes which I've never seen before but going into reverse and park again seems to rectify that
Anyone come across this by chance? The gearbox was working fine before the install (I wasn't fitting the kit to try rectify an unrelated issue, just needed a fluid change)
Get your transmission tuned to suit
Transmissions are like engines, when you mess with them they may/will require a tune to run problem
Disclaimer: I'm new to playing with transmissions and the transmission I have is a 4l60e
I get my transmission tuned at Craigs Automatics whenever I change power or gearing
  • 4 weeks later...
The 2nd gear jerkiness, is a standard for the shiftkit for a lot of people. It can be quite clunky.
The transmission is 'adaptive' and it will take a while to drive and for it to 'relearn'. Sadly when you clear the ecu etc it doesnt actually clear the tcm. I am unsure of anythign besides consult being able to clear the parameters also.
As for the rest of your sumptoms are you having any other issues? Only time ive had the dash dissapear is when my IPDM got wet, that also made the gearbox run  full line pressure constantly.
Thanks. Things have improved but there is some odd shifting behaviour once it gets hot. I've ordered a trans cooler for it.
Manual mode seems a lot better.
The P symbol dropping out seems to have disappeared too.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
