Hey Guys
I have a 1994 R32 GTR which I have owned for years. It's always been silky smooth yet the other day I started it and the car felt weird.
Stationary at low RPMs between 1000-2000 the car vibrates. You can feel it through the seat but mostly the steering wheel. No knock, no smell, no issues driving just this weird vibration. Above 2000 you don't feel it anymore. Not sure if it goes away or can't be felt due to higher revs. Car just finished a 400KM drive a few weeks back without any issues.
I have seen this problem on many forums including SAU and nobody ever posts whether it gets fixed. Hoping this time someone can give me feedback or has fixed it so we can update the forum with a fix.
How is the idle? Are all injectors flowing properly? I recommend running a cylinder balance test where you disable injection on each cylinder at low idle and see if any one of them seems to have a weak influence on idle RPM, they should all drop the same amount of RPM when you turn it off.
On 2/6/2022 at 7:42 AM, White GTS-T said:
You've owned it for years, have you ever replaced the engine mounts? I'd be checking and testing all the engine mounts first, including the gearbox mount.
No I haven't. I was thinking this could the case but wouldn't there be rock in the engine when starting?
Idle is perfect. No hunting, very smooth. I haven't done the cylinder balance test yet why would it only do it at low RPM?
Yes, if the engine is vibrating but running smoothly it is probably not a missfire.
I'd check all of the accessory belts carefully, and make sure all of the accessories are mounted properly, eg power steering pump is tight. There are lots of other rotating bits that could come out of balance (eg, the harmonic balancer itself) but at least you can check those easily. If you have a timing light, check the base timing against the balancer too, if it is miles off it may be the balancer
  • Like 1
On 2/7/2022 at 1:22 PM, WantGTR said:
if it does end up being a balancer, hopefully you havent damaged the keyway on the crank. best to get a new keyway as well.
So the balancer can damage the keyway immediately or does it take a while. Problem hasn't been an issue for long
Depends how bad the vibration is guess. if the balancer bolt backs out or the balancer is bouncing around it can do damage yes.
Last year this happened to me...
If balancer has become faulty and loosened after being tightened to 460nm + there is sometimes another cause. The most overlooked part that makes them come loose is not the bolt or balancer itself, it's the rubbish lower factory timing gear and shields. They seem to crush after extended use or under high loads.
Ross have an excellent billet full replacement for this which I have now used.
If the balancer needs to come off I strongly suggest inspecting the lower timing gear area. Dead give away for being crushed is when the back of the balancer is touching or almost touching the lower timing cover.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
