FYI you don't need that (or any) bolt to remove the rotors. Yes it might make it a tad easier if they are stuck on, but to be honest once the brake calipers are taken off, the rotors come off with a half decent whack or 2 with a hammer. Often they just come off in your hand with little or no persuasion.
  • Like 2
On 2/17/2022 at 10:07 PM, Nightcrawler said:
...snip...
Yes spacers are a bad idea - MUCH better to get wheels that actually fit and have appropriate brake clearance. Good luck in your search.
On 2/21/2022 at 6:58 PM, V35_Paul said:
Ozzytyres 馃憥
Yeah, I wouldn't trust them. But they did have some cheap tires & wheels (which I checked for reviews on a different/independent web site). Suspicious thing for me is that they allow you to specify exactly the offset you wish. With the spacers so prominently displayed on the walls, I suspect they achieve your requirements using spacers.
Another thing that these guys have and do actually need, is that you can sit in the showroom and watch the work being done through an observation window. At least at Hoxton Park.
As for my search, on an unrelated note, found a site that allows you to preview your car with the wheels. But in contrast to the image it generates, my windscreen is not tinted... But I would also add a flat hub-cap to the centers. You can grab the url from the image to have a play.
On 2/20/2022 at 11:41 PM, Vee37 said:
Well, I threw away the one that was taken off (may still be in my trash). Your welcome to the other one.
As for using the bolt to help remove the rotor, the wheel guy who tested my wheels fitment, thought it was a simple metric bolt you could get at bunnings. Do they have a similar bolt/stud on the rears?
Thanks for the offer but I kept mine after I removed them from the old rotors. They're safely stashed away in my well organised bits and bobs rack.
The rears do not have anything like that because you have the parking brake mechanism sitting within the hub, so there's no point in the bolt having the purpose of helping the rotor off the hub because you've still got to adjust the parking brake shoes to retract them from the rotor's hub for removal anyway.
This is true. I just like to avoid things that require me wearing earplugs. Even we drummers value our hearing. :)
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
