Right So got my s3 r33 gtr gearbox to go into my 89 r32 gtr
Gotta do the pull to push conversion...so means draining the oil in the box to take the front plate off ,my understanding is the oil in the box currently is just a small amount of storage oil?
is that the case?
if so is it safe to refill the oil out of the box with the permanent stuff before attaching the transfer case  and getting it on the car or is there a good chance some will spill out the back
during this process? anyone done it this way?
Cheers!
https://www.sau.com.au/forums/topic/483315-gtr-gearbox-install/
And me sorry too, because I followed your lead with brain switched off and I also actually meant "do you really want to go pull clutch?" So my 1st post should look like:
Do you really want to go pull clutch?
Would it not be easier to just drill and tap for the push clutch on the R33 belhousing and use the bits you need from the R32?
Would it not be better to go all modern and concentric, if not wanting to retrofit push clutch?
Not really sure of the order you are thinking, but you need front plate with chosen clutch pivot and xfer case on before you fit it in the car.
Yes you can fill the gearbox and transfer case before you install it, and no you won't lose any (or much) oil if you do it that way
On 2/10/2022 at 11:57 AM, BK said:
If swapping pull to push, remember the Threebond not threadlocker on the input shaft front cover bottom 3 bolts when refitting, or else it will leak.
whats the difference?  is this the stuff?
https://www.repco.co.nz/en/car-care-panel/adhesives-sealants/gasket-cements/threebond-high-temperature-rtv-silicone-liquid-gasket-250gm-grey-1215-250/p/A1130561?kwSearch=threebond
You can use either of the above but preferred is 1207C - the red / brown stuff as it is anti sag, cures faster, has higher temp rating and a superior oil resistance to the ones mentioned. Same stuff used on an RB26 sump.
Never used that CRC one but "appears" to be the 1207C equivalent. Threebond is actually what Nissan sells as their factory RTV from Japan (sourced from Australia).
Some people still use the 1215 grey as it cures slower on sumps, which gives more time when stuffing around fitting it - but it is definitely not as high temp or as oil resistant.
Look harder, it's there. 15 - 20Nm something like that. Seriously though just use a 3/8 drive and tighten it moderately. The sealant on those lower bolts are definitely more important than the exact torque settings.
Transfer case to box torque settings yes, but below was referring to gearbox input shaft front cover
On 10/02/2022 at 7:19 PM, boomtheroom said:
Btw Anyone know what the torque settings are for these cant find anything in the workshop manual...
I'm sure Duncan will have that page handy for exact torque 👍
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
