Hi, used this site plenty but finally signed up.
I'd like to find out more about what's been done to my recently purchased Black V35... as far as any history goes it stops at Grafton by a girl who knew nothing about the car.
I can tell it's had some work but also looks like a small accident at one point? Besides mods I CAN see, I'm curious to know more if I can find the old owner/s.
To help anyone recognise the car, its got a kinetix plenum, nismo sways, english nav screen, asuka video box?, 'repainted driver front fender', silver mirrors..., jvc headunit, viper security system, carbon intake tube, aftermarket mph guage..., some extra ground wires, apexi throttle controller, unconnected oil cooler, aftermarket headlights, various support parts for the bumpers removed, and some interior carbon wrap...
Attached is the only photo I've taken so far... 馃槄
Edited by S1mpl3_V1C
Remembered more info to add
https://www.sau.com.au/forums/topic/483316-history-backtracking/
Wow, that's my old car!
I crashed it in Aug 2018 and it was a write-off (I assume stat write-off since it has been repaired and re-registered). I hit the front right hand corner and it damaged the bar, guard, light support (I think it snapped one of the headlight mounts), totalled the oil cooler, and cracked the front carbon fibre support (which was the main reason for the writeoff - insurance said the composite carbon front nose is around $15k brand new out of Japan).
Does it still have the black SAFCII mounted where the ashtray used to be?
I was going to say it was your car :)
I guess you mean, not a stat write-off?
Probably not too hard to repair those items if they had a donor car.  The question is, has it been repaired properly?  or just enough to get a RWC?
Hahaha yeah bloody right 馃槀 yeah it does. That's amazing. I've gotta pm you
On 2/10/2022 at 9:07 PM, Ben C34 said:
Hmmmm.
Car looks shiny. Fix up the weird bits and drive it.
Yeah thats the idea. I'm fortunate enough to have a parts car. But she'll be mint when I'm done with it haha
Can tell you it's (rad support) still cracked and crap 馃槀 I've already straightened the rear bar out because it was missing clips and sagging. Headlights are in the middle of a swap but I need a ballast as one was left without a cap and has given out.
    • Thanks Murray I really appreciate the help.
    • Do I think this is worth fixing properly? Nope. I'd use this project car to practice skills you want to learn. Once you're happy with your new skill set, I'd move the car on to the next owner.  However if you think it is worth fixing, there is only one scenario I can think of that it makes sense.... I don't know this platform so I can only guess, lets assume the roof attaches like this -  Where the red lines are, that is the frame/body of the car. When the car was manufactured, we'll assume they spot welded it to those points on the body.  If this is the case, you could drill out the spot welds, then weld on a replacement roof. It is reasonable to assume that with enough practice, you could spot weld the roof back on.  If the roof doesn't attach like this, say its all one piece... your back to the original plan of a cut and paste job. I wouldn't attempt it.  Only you can answer that one. We already know what the previous owner thought lol. You'll have to decide how important it is to you.
    • Maybe I'm just making a bigger deal of this than it is.
    • Ok.  Ok...  Last question... Do you think it's worth fixing this again properly at a later date if I work on my welding skills? Maybe the entire roof? Or is that just nuts for anybody?
    • I know you'd like to believe that it won't spread, but it will.  Just pretend that it wont. Give the roof a little pat and say she'll be right.... She'll be right
