Basically what the title says, I'm looking to upgrade the brakes on my R34 GTT as the stock ones I have right now are seized. I was looking into a G35 Brembo kit but was just wondering how it would fit in terms of the caliper bolt holes, or if I'd need to modify them in any other way.
I live in Canada so parts are hard to source.
Also, in terms of rotors what would be the best option?
Thanks
Why not just fix the stuck pistons in the 34 calipers?
If you want to avoid doing, you know, basic maintenance work, in favour of upgrading something for the sake of it, then buy an ATTKD or similar aftermarket 6 piston kit with calipers, pads, and rotors, to suit the actual R34, instead of going through all the stress of working out if the caliper offsets and disc hat heights etc etc from the 35 chassis cars will work on your 34?
Or....you know....you could do some searching on here, because the subject of brake upgrades from the 35 chassis cars is not exactly a brand new one. People been putting Z33/4 Brembos on R chassis cars for nearly 2 decades now. There might* even be a comprehensive write up on the subject mentioned many times on this very site.
*definitely.
What I want to do is the CTSV Brake swap. The 6 piston kits are incredible, the pad size is ridiculously bigger than the Attakd/KSport/G4/What have you kits. Plus they are OEM sized, OEM calipers etc.
They make them for many USDM Nissan cars. Some of them are very VERY similar to R33/R34 to the point where one of the conversion kits would likely work with very minor modifications.
https://ctsvbrakeswap.com/
Given there are kits for S15 and S15's can quite often use R34/R33 brakes as well, this should be minimal and should work. It's minimal in general by drilling out one bolt hole to be larger diameter which is about as hard as it generally gets.
I have the Alpha Omega Evo caliper adapters, braided lines and Evo 6 Calipers and Evo X rotors (this is on the front only, rears are stock)
Apart from trimming the brake rotor shields, this is completely reversible and pretty straight forward to install - complete bolt on. They work very well, I've done 2 Adelaide Rally's, can't fault them
*definitely.
On 2/10/2022 at 1:14 PM, Dose Pipe Sutututu said:
350Z 324mm Brembos bolt up (use existing R34 GT-t caliper bolts & brake line).
Wow look at that after a quick google search........
Blow Your Mind Wow GIF by Product Hunt
http://www.trak-life.com/diy-350z-brembo-brakes-conversion-nissan-skyline-r33-gts-t-gts-gts-4/
@Dose Pipe Sutututu when you going to get back into doing some articles?
  • Haha 1
Hmm not too sure, been so lazy and unmotivated to do any car content.
I should though, these days I tend to just post up on IG about the mods & thought process.
Do the rear and front calipers + 324 rotors bolt up directly or just the fronts?
Only fronts.
Rears you will need to cut off the mounting tabs and weld on new ones OR weld on the GKTech ones.
  • 1 month later...
I was considering the 350Z brembos but opted to get the stock ones refurbished and some higher quality pads (Dixcel Z type vs OEM previously) plus slotted rotors - bit of a waste for the rotors but I needed new ones anyway.
Stopping performance is plenty for my track use, in fact it was pretty good anyway on the stock brakes with semi-slicks.
  • Like 2
Just on that, great tyres like semi slicks are probably the best upgrade for braking you can do....far less braking needed and you are going faster overall anyway.
  • Like 1
On 11/02/2022 at 12:55 PM, Tobz said:
i did the alpha omega evo brembo upgrade... well worth it
You mean the Ford FPV R spec 6 pot Brembos with the Evo 10 rotor combo on the front ?
I think I want 🤔
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
