Engine: RB25DET s2 (in a 1996 R33 gtst)
ECU: Stock
Engine Mods: •Gktech fan/adapter •Gktech master cylinder stopper •BoostDoc billet half moon seals/oil splash plates •OG valve cover bolts •Greddy FMIC w metal piping •Greddy Trust BOV •red top coils (dunno the brand tbh) •Greddy iridium plugs (0.08 I believe pregapped) •aftermarket coil harness •Metal head gasket (on before I bought the car) •HKS EVC IV (I think) boost controller •cone filter cai metal •Tomei forged Downpipe •Viper 100cpsi 4” high flow cat (cerikoted) •nur spec exhaust •almost every single hose has been replaced with new/improved silicone ones (aside from the fuel lines and a couple breather hoses), all couplers are within a years old aside from one or two on ic piping
probably forgetting some engine mods but whatever if you have any questions just ask me please.
So, over the last week or two I’ve been having this issue with boost that I can’t figure out. My target boost is .85 bar, which I’ve been safely running and hitting for over a year and a half with no issues. Basically, if I floor it in 1st to redline I’ll hit .85 bar no problem and every gear after that it just doesn’t want to make it to .85 bar…. It’s like whatever I set the boost to, I can expect to hit .1-.05 bar below my target boost. Usually I let off when I feel it, because the engine sounds “different” once it’s getting closer to .6-.7-.8 bar. It’s like a dull sound that sits at the same decibels basically, and when it gets to this spot it’s like a dead zone for power, the boost feels like it’s completely gone. When I’m at this point in boost it sounds almost like I have a major vacuum leak from the drivers side, shhhhhhh! If I shift out at this point I usually hear a pop of some sort. And if I try this again the boost will feel fine up to the same area, and like I said 1st usually runs fine and hits target.
so, today I decided to send it. I brought it to the point where the boost does this thing, like every other time it struggles to get closer to target (about .1 bar under set boost of .85 (the higher gear the less boost I get to) & (I set it to .8 bar and it seems to do the same thing about .05-.1 under,  if I set it to .9 bar it seems to hit .85 if I remember correctly) BUT this time I had it set to .8 bar and held my foot down even though there was boost issues, same stuff occurred but while I was holding my foot down through it the car JERKED HARD once, the boost looked like it hits target and went way down for a split second and then started coming back up, the engine sound and power loss issues still present. But that jerk and pop the car makes is unsettling to say the least. I tried it a couple more times and no matter what the same situation happened.
Fuel pump seems good, injectors are blowing their loads, I’ve reset the ecu, checked for leaks, reset the boost controller and reconfigured it after the most recent mods (cat and downpipe) it has never done this before and even after the downpipe install it’s been handling anything I throw at it. Turbo spools and sounds beautiful, oil and filter are new as of a day ago, fuel filter was replaced 6 months ago. I can’t figure this out. My gas tank is cracked slightly and I’ve been busting my ass for weeks trying to fix it but even still the cars been running just as god intended up till now.
The shhhhhhh! I hear out the drivers side makes me think it’s a leak… like a leak that really just shows up at .6-.7 bar and up or something, because I don’t hear it at all any other time. Someone please save me from myself.
On 2/10/2022 at 4:53 PM, GTSBoy said:
It's going to be a plenum gasket leak, isn't it?
You think so? The middle gasket on the plenum has been kinda iffy looking and I have a replacement ready to swap in for it but it hasn’t done this before and I haven’t ever changed the gaskets on the plenum… but I’ll change the gasket I have today and report back if anything changes or not. Thank you.
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
