Do the bottom port test again off car to confirm it definitely passes to the top port, therefore being faulty. If it's got a split diaphragm it'll be obvious when disassembled with a tear in it - It's about the only thing that really fails on them.
Just be careful when you pull the gate apart - remember big spring in there that can send the cover into your face if it flies apart without keeping it compressed on disassembly.
  On 16/02/2022 at 6:32 AM, Chereboy said:
Expand
Good work, you owe me a carton 😄
That gate diaphragm is exactly the one I linked you to from RHDjapan, so around $150.
HKS part 1499-RA057
  • Like 1
HKS part 1499-RA057
Expand
Thanks soo much man, I honestly appreciate it soo damn much. You've been a huge help.
HKS part 1499-RA057
Expand
Also just curious on how I would fit it on as the one on my wastegate is round but the online one is squared off, do I just run a knife around the outside of the wastegate after clamping it shut? Thanks again
Nah the rhd one is round - have a good look at all the pictures again - it is curved and just a bit wrinkled up. It'll take shape when installing.
Expand
Damn aha, you're spot on again
  On 18/02/2022 at 9:46 AM, tridentt150v said:
On another tack...10psi sounds a bit low.  You would need to test, but a 14psi would probably suit that turbo and setup a bit better.
Expand
Hey mate, so your saying it would be worth my while to have a 14pound spring in there instead of the 7pound one? I'm also going to be tuning the car soon after the diaphragm arrives and I'll probably be pushing close of not a little more than 20psi. I'm also probably just going to have the ECU control the boost so I'll just delete the Blitz one
Expand
The general rule is that you do not want to use a spring that is less than half the boost you want to bleed up to, and more spring is generally better than less. So for 20+ psi, you definitely want to be in the 14 psi spring range, rather than 10, and you definitely don't want to be using a 7.
Expand
Alright mad, too easy, I'll definitely be sourcing out at least a 14 psi spring setup. Thanks mate
Edited by Chereboy
Expand
As your HKS standard gate has no spring preload adjustment on it, I'd say you want the purple spring as it should be about 1.1 bar fitted being that's minimum on the adjustable version  Available springs from RHDjapan attached, although HKS themselves say only the yellow and purple springs are available now and that the original standard gate spring selection is discontinued.
https://www.rhdjapan.com/search/brands/hks/category/turbo-and-na-systems/?q=Spring
Alright, I'm gonna order the purple one tomorrow, I'll see if they can add it to my pending order for the diaphragm as it's apparently going to be sent out on the 21st.
Anyone know how long I'm looking at it taking to reach Sydney NSW? I paid for the DHL shipping and wasn't really sure what it meant by 1-5 days as I'm sure it will take much longer than that to arrive and 5 days will be the 21st when I think they are saying it will be sent out. Thanks guys, don't really understand their shipping system
Screenshot_20220220-201933_Chrome.thumb.jpg.cb4ff0e834a1f1d482a3335fe7b3469e.jpg.
Edited by Chereboy
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
