Gday SAU,
On my R34 sedan, the doors love to close shut on their own, and are prone to swinging wide open on a windy day. During my search I've learned about the R35 door link upgrade, however; people have only done this to coupe R34s and S15s as far as I can find. The Nissan EPC has told me that the sedan and coupe have different door links, so I'm not game to buy an R35 set on the (wishful) chance it works for sedans.
Has anyone found a clean solution to this problem, or tried the R35 links in a sedan?
https://www.sau.com.au/forums/topic/483340-r34-sedan-door-link-upgrades/
The R35 set works in Sedans. I have a full set, all 4, there is a left hand R35 side and a right hand R35 side. You need 2 of each.
The only things you will need are 4 nuts which are not included.
It really does feel and work great.
  • Like 2
  • 1 month later...
Hey @Kinkstaah, what model is your sedan? ER34? I'm trying to work out whether I can fit the same door links on my WGNC34 Stagea. Going from EPC data it looks the same.
On ER34 it is 80410M for the front door and 82430 for the rear door. Which matches the links on my WGNC34.
Also, the 4 nuts are for 2 doors, right? So 8 nuts for 4 doors? Thanks!
As an aside, there are some more details with the R35 part numbers in this thread.
Quote
Nissan 80430-KB50B - STOPPER, DOOR
Nissan 80431-KB50B - STOPPER, DOOR
Nissan 80440-AG000 - COVER, CHECK LINK RH
Nissan 80441-AG000 - COVER, CHECK LINK LH
4 x M6 nuts
Hey mate, my sedan is a R34 Series 2 GTT. From memory you need 2x nut per door as per the image in the linked thread which also is correct. You'll be happy every time you open a door, which when you think about it, is at least 200%+ of the time you drive the vehicle.
  • Thanks 1
Man, tell me about it. I think personally I snapped the day I had to wedge a broomstick in the door to keep it open in the perfectly level courtyard. It was ridiculous. So yeah I'm super excited about this. Looks like the Stagea uses the same bits for the doors.
Just looking for somewhere to get them from. Amayama has them, but a bit of a lead time. Trust-kikaku has them in stock but more pricey. Enquired with jp-carparts as well, see what they say.
Just as an aside, the door links in the R34 sedan and WGNC34 Stagea are not the same. I didn't look at the epc-data correctly. I must have been blinded by the glorious fantasy of having doors that actually work.
See for example the two diagrams of the doors: R34 <-> Stagea. 80410M in the middle. R34 uses 80430AA000 and Stagea uses 804300V000. The doors also look nothing like each other.
Anyways, I ordered a set of door links before realising so will at least have a look if it can work. I'm just glad I only ordered the links and not whole bloody doors. That would have been pretty funny in a not really funny kind of way.
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
