Hey Sau,
First post here. I imported an R34 GTT into Canada last year, and its been great so far. Its parked up for the winter right now :(, but at least its giving me time to save for mods. I've been using this forum extensively for info on all sorts of things so far. Here's a shot of it on the drive home from the port.
I am wanting to get a 1 piece bellmouth downpipe similar to the JustJap downpipe. However, I cannot find anything in North America for the 34, and shipping from JustJap is over $400.00. However, I've found a couple R32/R33 downpipes from sellers in North America. I found one other thread on here discussing the fitment compatibility, but there was never a resolution.
I know that the lengths of the exhausts are different between the R33 and R34, but I will be getting a custom Decat put it eventually, so the length of it wouldn't be an issue for me. I'm wondering if anyone can confirm if the pipes are the same shape, except for the length?
thanks!
https://www.sau.com.au/forums/topic/483342-r3233-downpipe-on-a-r34-gtt/
I recall the flange on the cat side is the only difference (orientation) the dump/downpipe part is essentially the same as a R33.
Since you're going to cut/shut it for a 1 cell cat - your fabricator should have no trouble making it fit.
On 2/17/2022 at 12:04 PM, tylink720 said:
We've gotten clapped with snow this winter, so Ill likely only be taking it out in May
Are you on the east or west coast?
 I’m on the west and seems to be okay for snow now but yeah did get a pretty big dump of it this year
Right in the middle lol, Manitoba
  • 6 months later...
Update:
I put the ISR R33 bellmouth downpipe in on the weekend and it does fit. Obviously it doesn't bolt right up to the catback due to the different length, but it squeezes in onto the turbo side
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
