Just wondering if anyone here has put in a bee*r limiter into there rs4s or any car running an rb25 neo and neo ecu, only asking because from what I’ve found online the s2 an neo oinouts are slightly different? (Correct me if I’m wrong of course) also buying a bee*r but it’s second hand so I don’t think it’ll come with any installation papers so any advice is greatly appreciated!
i will be asking one of the other sections in the forums so if you see this post twice sorry for that haha.
Thanks again!
Ron
https://www.sau.com.au/forums/topic/483346-beer-limiter-and-neo-ecu/
On 2/16/2022 at 12:12 PM, Ben C34 said:
Surely you wouldn't actually do it?
What do you gain, vs the known risks. Definitely doesn't add up.
For me it’s truly just for fun, no real gain power or longevity wise but would like to have a good smile and give my friends a scare lol, I guess I should’ve mention I already know it’s not good for motors and just doin it for some fun!
with that said also don’t plan on keepin it in my car and plan for an ecu to have a more proper limiter than the bee*r and more control of the car, mostly for some good fun then switch it over to some rust bucket for more fun haha
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
