Just wondering if anyone here has put in a bee*r limiter into there rs4s or any car running an rb25 neo and neo ecu, only asking because from what I’ve found online the s2 an neo pinouts are slightly different? (Correct me if I’m wrong of course) also buying a bee*r but it’s second hand so I don’t think it’ll come with any installation papers so any advice is greatly appreciated!
Apologies if this has been asked and answered before, I haven’t been able to find much out but maybe I’m searching the wrong terms.  Either way definitely looking for any help!
Also if there’s a neo pin out sheet as well as what each wire does for the bee*r because as I stated I believe it won’t be coming with any sort of instructions so info on what each wire means and where it should hopefully go to is extremely appreciated!
still tryna learn as much as I can about rbs and all the little bits with it so even little bits of info is amazing!
Thanks again!
Ron.
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/
in the sump, oil pump and head when your stock oil pump grenades from the violent and uncontrolled ignition cuts caused by the Bee R oil pump, valve train destroyer.
I'll be honest with you, if you want bang bangs - get a proper ECU where you can gradually cut ignition and also inject more fuel in to cool down your valve train + make the bangs bangs (if you desire). Those Bee R things are just horrid, absolutely just garbage.
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961224
Ahhh fair enough thank you for that! Already got the limiter comin In and don’t plan on using much and do plan on the ecu to do that stuff later on just waiting till I have more parts for the ecu :)
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961229
On 2/16/2022 at 2:53 PM, GTSBoy said:
Listen to this man ^, and the man in the other thread, and also don't start multiple threads on the same website for the same question.
Bee R's are dumb engine destroyers.
Do apologize for making multiple posts kinda thought having it in different sections would be okay cause different people would be seeing it rather than the stag section that sees 1 or 2 posts a month, and yeah as I said don’t plan on using it much cause I don’t plan on blowing the thing but don’t mind hurting the motor a lil bit. (Would like to do a rebuild on it anyways) Do appreciate the info tho cause yah helps me out a lot as I’m still learning!
:) thanks again guys!
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961231
On 2/16/2022 at 3:22 PM, Dose Pipe Sutututu said:
Skip the Bee R, just sell it.
See screen grab below, there's no way a Bee R gives you this kind of control.
Not necessarily looking for control atm because my car is essential stock with a modified exhaust and no cats, just looking for some fun for a moment even if it hurts the motor :)
probably sounds quite dumb and honestly won’t disagree cause it 100% is but I don’t mind, I enjoy doin the stupid things even with the risks, cut up my intake last week and didn’t know if I was gunna get my car on the road for work hahah.
Also probably will sell it, I’m getting it for quite cheap so don’t mind letting it go eventually but do plan on puttin in other cars later on!
also I’m guessing that was pulled from a haltech?? Just wondering because it looks like a very simple interface and trying to decide going haltech or link ecu when the time comes! And yes do plan on the bang bangs with the proper ecu and tune! Just been something I always liked to hear.
also thank you again and prolly will keep thanking y’all for the info, I’m young and dumb so everything helps me learn!
Edited by BiggestRon22
Forgot to add a bit
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961236
Just warning you :)
At the end of the day it's up to you if you want to lunch your motor! If you were wiring this to a 1JZ or 2JZ then it wouldn't be so bad, but everyone knows on this forum aggressive rev limiter & stock RB motors don't mix.
And yes, it's a Haltech - I personally prefer working with them however what you like is very subjective. I prefer the user interface vs. say of a Link. Sure Link has more features, however most of the features most people (including myself) don't really need.
It's like getting a flashy MoTec then not running traction, DBW, inputting telemetry, fuel modelling, etc.
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961239
On 2/16/2022 at 4:15 PM, Dose Pipe Sutututu said:
Just warning you :)
Ahhhh fair enough man man thank you for that, yeah I know what you mean the jzs definitely can take more of a beating than the rbs haha, won’t be doin it more than like 10 times over a few months cause yeah proper ecu is the way to go.
yeah I’ve been looking at ecus and can’t really decide, I really like how the haltechs do have the simpler interface and from what I know a lot of tuners know how to tune them as well, but yeah definitely looking at the link mostly because it would be cheaper and does the same thing but mostly just for the price, first pick was a haltech so maybe I’ll bite the bullet and save up a little bit more so if I need to go in there and do a small tweak it’s not like opening Pandora’s box yknow hahah.
also I’m looking at the plug and play ecus from link and haltech, I’m guessing the platinum pro would do just fine even tho they are older, not completely looking for the launch control and the other trinkets the elite 2000/2500 has but with that said the link I believe has those features for the same price. Guessing it’s more which one I want more but wouldn’t mind getting some extra options on the three ecus (again it’d be the haltech platinum pro/elite2000 or the link g4x)
as I keep saying thank you for all the info man!
https://www.sau.com.au/forums/topic/483347-beer-on-neo-ecu/#findComment-7961240
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
