Hey all,
I'm getting ready to put my RB25 into my car and when I went to pull the oil pan just to inspect its condition and I found the previous person had used that a lot of that annoying red RTV. There was RTV stuck onto the pickup tube strainer as well! Should I be concerned? I didn't see any bad signs of RTV anywhere else in the engine when disassembling and replacing parts (i.e. Timing belt kit, Valve covers, water pump, Intake manifold etc.) but one thing I didn't replace was the oil pump as it looked not as used. I removed the oil pickup tube and cleaned it out really well as well as any excess RTV I found around the mating surface of the oil pan, all seems well around the crank and con rods also.
The impatient side of me wants to just put the engine in and start the car but I want to do things the right way when it comes to my build; so I'm asking for experienced advice on what I should do in this situation; any help is appreciated
Edited by Bxcliff
On 2/16/2022 at 8:44 PM, Duncan said:
Given that you've looked for other excess and have the sump off, I would put it back on without excessive sealant and never think about it again
Thanks for the response, I was thinking the same way but just wanted some reassurance lol
Cheers
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
    • Yeap, legal modifications are limited  We have rules and regulations on what you can do legally This is for NSW, other states have different governing bodies  https://www.nsw.gov.au/driving-boating-and-transport/vehicle-registration/how-to-register/registering-a-used-or-secondhand-vehicle/modified-and-non-standard-vehicles https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf Lots of people just roll the dice though and just hope they don't get picked up,  as the police and RMS occasionally run roadside inspections, getting "defected" for not complying can be a painful and expensive experience
    • Out of curiosity, I believe the title of "Engineer" is not protected in Australia like it is over here. I'm curious, does Australia actually have professional engineers do vehicle inspections?  If so, Jesus Christ what in the f**k.
    • When it’s broken I take one of my other r33s out its a little more reliable
